PC repair will not load system everything is not in english any more I chang the cmos & pull the battery and change the harddrive from 7 gig to a10 gig Ithink lost the BIOS I think THANKS JEFF
    Scholar:
  • 64 Answers
Hi help46,
I've read your issue a couple times and I think I'm going to need more information from you.
First of all, changing the hard drive out isn't going to do anything to the BIOS unless you're using an ancient PC (like a Compaq DeskPro) that stores the BIOS information on the hard drive itself.
Are you using a desktop or laptop computer? Please reply with detailed information on the make and model of the computer and I can help you more.
Ben
Posted on Mar 21, 2008
How to install xp on acer aspire m5641? always bsod
Maybe the operating system disk you have is bad if it remains on 0%.
I think the AHCI is a problem are you sure it can't be changed?
Remove the power cord, Remove the cover then remove the cmos battery from the motherboard. It is a shiny looking battery about the size of a nickel. You will need a flat head screw driver to pop it out. Let it sit out for about 30 minutes. Press and hold the Power Button without the power cord or cmos battery for about 30 seconds. The plug the power cord back in and try going into the bios and see if you can change the AHCI. If not just try loading the operating system without the cmos battery.
If if fails again, put the cmos battery back in. I think maybe one of your memory chips is bad or one of your memory slots is bad. Try using just one of the chips in the Dimm 1 or Dimm A slot, the first slot. Retry loading the operating system and if it fails, try the other memory chip in the slot.
May 01, 2012 | Acer Aspire M5641 PC Desktop
How to fix stop: 0x000000f4 error
Reset or CMOS Battery or Change or CMOS Battery.
It is blue Screen Error.
Mar 14, 2012 | Microsoft Windows Xp Home Edition English...
How do i change a cmos battery in a toshiba 1425?
Here are the instructions for a similar laptop.Step 24 is the key to removing the cmos battery (rtc battery)http://pinout.net/disassemble/content.php?nid=173
best regards,abdielfort lauderdale network support
Nov 19, 2011 | Toshiba Computers>Laptops Satellite A10 PC...
My HP 530laptop won't see any hard drive installed. No hard drive listed in bios . Can the bios be repaired if corrupted and id so can someone tell me the procedure? thanks in advance
If you want to try to repair the bios, in most case clearing the cmos would do it, and reset it to factory default. To do this, you are going to have to tear your laptop apart until you can get to the motherboard, there should be this nickel size battery installed somewhere on your motherboard. You will need to take this battery out for at least 15sec to let the cmos reset. Reinstall the battery, and put your laptop back togheeter, once powering up, it will prompt you to load default which you will have to set your system time agian. If you just want to load default value and not totally clear everything, you can go into your bios menu and on the exit tab, there is a load default value, and you can do this to set default value, but will not fully clear the bios. In your case of your laptop not seeing or reading your hard drive, ask yourself is it one harddrive or any multiple harddrive you had previous installed. If it is only one harddrive or the original harddrive, It could be dead, damaged, and that why the O.S cannot detect it and so with the BIOS menu too. Other then that, it could a bad hard drive expansion connection, since Hp laptop are known to heatup pretty hot.
Jan 17, 2011 | Computers & Internet
I have an IBM ThinkCentre S50 PC Desktop 8183... problem is that the BIOS wont load or save default or customised settings so I cannot change the boot order to load OS from CD... I have removed the CMOS...
Regarding settings not saving
You mention that you removed the CMOS battery... You normally need a working CMOS battery [one that is not flat] for the computer to be able to remember changes to the BIOS settings.
Regarding BIOS being in Spanish
I would hope there would be a language option somewhere in the BIOS settings where you might be able to select English as the display language.
Nov 08, 2017 | IBM ThinkCentre S50 PC Desktop
Windows xp professional won't complete setup.
Its an hardware error. You have tech support with MS since you bought the new XP try to see if they can tell you what is the hardware its complaining about.
Feb 26, 2010 | Microsoft Windows XP Professional With...
How do I replace the CMOS battery for Toshiba Satellite A10-S169. Thank you
The cmos battery in laptops is not easily replaced. The whole laptop must be taken apart to get at the cmos battery which is soldered to the motherboard. You should be able to find a new battery on ebay but then will require someone to take it all apart and resolder the new battery onto the motherboard
Jul 07, 2009 | Toshiba Satellite A10-S169 Notebook
Want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Jan 25, 2009 | Toshiba Satellite A10-S100 Notebook
HP desktop computer will not load...
what os you are loading?
did you purchased it with bundled os/softwares?
Apr 01, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
David Payne
David Payne
