Fujitsu Siemens Scaleoview C17-2 need pinouts (voltages from high voltage board)
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
You have to see on fujitsu Siemens page, for this supporting solution, there is a forum.
good luck
Open Sky
Posted on Mar 28, 2008
My Fujitsu siemens laptop model S7020D will not switch on and does not even show that it is charging
Try another power cord with the same voltage as yours. If still no luck the board may be blown.
Aug 10, 2011 | Fujitsu Siemens LifeBook S7020D Notebook
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
I have a problem with my fujitsu siemens scaleoview w19-1 monitor. when starting up the monitor, all that happens is a flashing blue light from the powerbutton... black screen and an annoying sound from...
It sounds like it is not getting steady DC voltage, that will be the first place to check.
From the spec, it does not indicate if it has built-in power supply or using the AC adapter. http://www.subincho.com/hardware_review/pdf/fsc_p19-1.pdf
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 05, 2010 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Fujitsu siemens scenicview p17-2 monitor flicker. Some time ago flickered about 20 min. after power on, but now always. Two monitors and the same bug.
IF you do not think it is the monitor, replace (if possible) the cable from the computer to the monitor. Sometimes the cable can be loose. Then, check the connection at the video card. The video card may be loose or may need to be replaced. Also, before you decide none of the above is what you want to do, verify that the refresh rate in the computer display control panel is set to the speed the monitor can accept. (right click on the desktop and pick properties then screen resolution/video/monitor options). Screen refresh should be 60hz +/- as a basis and adjust from there.
I really suspect the cable.
Brock
Sep 16, 2010 | Fujitsu Siemens Siemens Basic Line B17-1...
I have a Fujitsu Siemens Lifebook s7020 with no backlight. The display is showing everything but it's hard to see because there's no backlight. Everything is also fine with an external screen. I have a...
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer.
If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
Sep 07, 2009 | Fujitsu Siemens LifeBook S7020 Notebook
Conrac Plasma Display 4042
Found cold soldering point on tuner board.
Sep 11, 2008 | Fujitsu Plasmavision PDS-4203 42 in....
Computers & Internet Logo
497 people viewed this question
David Payne
David Payne
