Question about HP LaserJet 3055 All-In-One Printer
Scanner light stays on
I have a brand new LaserJet3055 the scanner lamp stays on. I took to a repair depo they replaced the entire top scanner assembly and bulb.
I got it back and the same thing the scanner light stays on all the time left overnight and it is still on. When you make a copy it says "Scanner Bulb is Warming UP" then it immediately says "Ready to Copy" I would think this should take about 10 seconds but I guess the bulb is already on go it flys through the warm up step.
Anything can be done to fix this?
Bulb may be designed to stay on to last longer -- otherwise it may cost about $100 to replace if it wears out sooner due to on-off cycling.
Posted on Jul 10, 2008
In the manual for a different brand of "all in one copier scanner" etc (Brother), it says even though their default timeout is 5 min.(for all the other parts of the machine such as fuser), but the lamp time out is designed to stay on for 16 hours.  If you turn the machine on and off every time, the manual says the bulb will wear out sooner -- I guess that is probably the reason for the HP lamp as well.
I have the same problem. I chatted with HP customer care for an hour but it can't be fixed. The only thing you can do now is set the power saver mode to 2 hours, so bulb will turn off in 2 hours. Only way to minimum power consume.
Posted on Jun 12, 2008
Error c3100
C3100 Scanner carriage problem
The home position is not correct when
the power is turned on or at the start of
copying using the table.
Poor contact in the
connector terminals.
Check the connection of connector YC4 on
the scanner PWB and the connector on the
scanner home position switch, and the continuity
across the connector terminals. Repair
or replace if necessary.
Defective scanner
PWB.
Replace the scanner PWB and check for
correct operation.
Defective scanner
home position
switch.
Replace the scanner home position switch.
Defective scanner
motor.
Replace the scanner motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Check if the mirror flames and exposure
lamp are on the rail. And check the scanner
wire winds correctly.
took this from a diffirent kyocera copier but it will be the same scanner related code
Jan 03, 2014 | Kyocera TASKalfa 180 Copier
Broken Lamp Blinking
Does the lamp light up while warming up? If not then there is a fault with the lamp driver.
Oct 25, 2007 | Ricoh IS 430 Flatbed Scanner
How do I replace light in HP Scanjet 5470c
  • 1Unplug it from the outlet.
  • 2 Unscrew the two screws on the side of the scanner that does not house the scanner and copier controls. Remove the plastic covering from the side of the scanner.
  • 3 Open the top of it0 and push on the glass. It will pop up. Remove the glass from the scanner.
  • 4 Remove the old bulb from its lamp by unscrewing it. Screw the new bulb in place. Replace the glass into the top of the scanner.
  • 5 Place the plastic siding back on the scanner and reattach the screws.
Jul 28, 2011 | Computers & Internet
I am geting an error code of c3100 call for service I am geting an error code of c3100 call for...
Poor contact in the
Defective scanner
PWB.
correct operation.
Defective scanner
home position
switch.
Defective scanner
motor.
The mirror frame,
exposure lamp, or
scanner wire is
defective.
Oct 13, 2010 | Kyocera Copystar CS-1820 Black and White...
How do I replace backlight on my bc895xlt
Greetings,
The bulbs can be replaced,
Remove covers taking care of the speaker wire. Remove screw for the green wire on disp. board and then the two screws holding the display board in place. Carefully remove the metal shield can with the four locking tabs. there are four grain of wheat lamps, two on each side of the display 12v/60mA DC. lamp # 7219 and radio shack sell them They are located in the white rubber holders on each side of the dissplay. unsolder the wires, pull up rubber white holder, remove bulbs, remove rubber light covers and put these on new lamps, slide lamp wires into rubber holders and then holders back to display pcb. Solder wires into place and repeat on other side of display. Usual common sence applies, be carefull, ect...,.
Apr 10, 2010 | Uniden BC895XLT Base Scanner
Modle 5222, scanner error?? any suggestions?
sure you lamp lights up when machine is powered on. open the top cover, turn power on. lamp should light and scanner should move. if either of these do not happen you will need to replace parts. if the lamp lights and the scanner moves your ccd could be bad. you may need a service tech. if the lamp does not light it is your problem. lamp, power supply, ballest, or main pcb could be the problem
Oct 21, 2009 | Lanier 1205 Copier
Fujitsu Scanpart 620c Leds error Amber on, Green blinking,red bli
Thank you for contacting Fixya.
You need to check the blinking times of the Paer jam LED. Then check the followings:
1. If the lamp is on, then ADF Switch is malfunctioning. Disble or short the switch.
2. If the lamp is off, then it is Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
5. If the Lamp is still off, then Lamp is to be replaced.
6. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Regards,
TechSatya
Mar 26, 2009 | Fujitsu ScanPartner 620C Flatbed Scanner
Error 3200 and no light from scanner Lamp on Kyocera FS-1118MFP
this error belogs to Exposure lamp problem ? cause of this error 1. Defective scanner PWB. 2.Defective exposure lamp or inverter PWB. 3.Incorrect shading position poor . 4.poor contact of the connector terminals Solutions:- 1. Replace the scanner PWB and check for correct operation. 2. Replace the exposure lamp or inverter PWB. 3.Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor. 4.Check the connection of connector YC7 on the scanner PWB, and the continuity across the connector terminals. Repair or replace if necessary.
Mar 24, 2009 | Kyocera FS-1118MFP Laser Printer
No letters come out or pictures
It quite simple to verify if the lamp is out. Just leave the the cover open and then switch the scanner on. The lamp should light up as the scanner initializes. Note if the full length of the lamp lights up. If it lights up only partially, then the lamp needs to be replaced. I doubt if the lamp is the problem though.
It is quite simple to get to the lamp but, you do need to be a little tech-savvy and own a soldering iron. Disconnedt the mains from the scanner. Turn over the scanner; the top is secured to the bottom by two recessed clips at the front button; release them with a screw-driver. Unsolder the two ends of the lamp. A new lamp can be purchased at a shop that sells computer spare parts. It's similar to the lamps that are used as back-lights in LCD screens. They come in different lengths so make sure you get one of similar length and solder it back in place.
Nov 18, 2008 | Acer ScanPrisa 640P Flatbed Scanner
Lamp replacement
Just replace the lamp! It's just a fluorescent light you can get anywhere. You don't need a new scanner, if I had to replace the scanner every time the lamp died I be in the poor house!
Sep 17, 2007 | Agfa DuoScan Flatbed Scanner
HP LaserJet 3055 All-In-One Printer Logo
426 people viewed this question
Seeker5211
Seeker5211
