Question about Intertherm P3RA-048K Air Conditioner
I need to wire up a capacitor to a aircondition unit
The name intertherm.
model of capacitor-s3aa048k
  • 236 Answers
If it is a dual capacitor this is the connections.
Posted on Mar 21, 2008
Why is my Intertherm nordyne ac unit fan not coming on?
It could be a bad wire or broken,burned etc. Or the capacitor is bad. The motor may have seized up.
Apr 29, 2014 | Intertherm Heating & Cooling
I have a intertherm e2eb-012ha. I need to know what size run cap to use. . The plastic coating has been melted so I can not see the run cap info.
It appears you may already have located your problem, the capacitors are very coming to burn out, if a motor will run after you spin by hand, mmore times than not the capacitor is the problem. The name tag on the equipment itself sometimes has the capacitor size and the motor nameplate usually does as well. you can call Nordyne support at 18004224328 and with your Intertherm Model number they can give you the correct capacitor size, which you can purchase at any HVAC supply house. If I had to guess, I would say you need a 5 mfd capacitor based on the blower size. but call them and verify. Also, most all supply houses that sell that capacitor can run the Intertherm numbers and see the correct size as well.
Jan 06, 2013 | Heating & Cooling
I have an old Intertherm gas-fired furnace, Model MGH-055AB which ceased operating last night. It was quite warm when I arrived home, and when I set the heat up a little, began to hum, but the fan would...
Tom P's answer is generally correct: The motor start capacitor is usually not the problem. However, in some cases, particularly on older furnaces, where there were capacitors of certain make and production run will prematurely fail. This happened in March on a mobile home HVAC unit where both the blower fan and condenser fan motor capacitors failed open circuit. Both caps were of the same Mfg, and production lot.
Here is a suggestion (for you or an electrically inclined friend): Locate a substitute motor capacitor having similar Mfd (or MF) and Voltage ratings. Remove power from the unit. Reach into the blower squirrel cage and spin it to verify that the shaft is not frozen. Pull the wires from the existing capacitor noting color and location. Connect the wires to the substitute capacitor and secure it place. Apply power and turn on the blower. A no start? Motor replacement time.
Nov 08, 2011 | Intertherm P3RA-048K Air Conditioner
Need Capacitor Size
try calling technical support of the company
Jun 04, 2009 | Intertherm P3RA-030K Air Conditioner
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Have a 620765 capacitor for my Intertherm ac outside unit. There are three connections on the capacitor. 1. Fan 2. Herm 3. C I have a yellow and red wire coming from the compressor. There is an orange wire...
pls connect capacitor terminal as folow
fan = connect wire come from fan
C = common -connect 1 wire from power
- connect1 to compressor term R
-connect 1 wire go to fan
herm =connect wire go to compressor term S
May 01, 2009 | Intertherm P3RC-048K Air Conditioner
Wiring diagram for intertherm ac heating unit
Your best bet is to contact Intertherm and see if you can get the Installation/ owners guide.
Dec 21, 2008 | Heating & Cooling
Wiring diagram is normally included and fixed to the inside cover of the electrical end cover of the control compartment. Instructions for wire size required and fused disconnect should be on the unit name plate.
Nov 09, 2008 | Heating & Cooling
Wiring diagram
i need a air conditioner wiring diagram
Apr 25, 2008 | Intertherm P3RC-030K Air Conditioner
Reinstall capacitor 370 vac from a/c
Here is the standard connection of dual capacitor. Actually you can see the diagram on the unit but Im not familiar with the Intertherm model. What can I give to you is only the standard connection of dual capacitor.
Feb 26, 2008 | Heating & Cooling
Intertherm P3RA-048K Air Conditioner Logo
233 people viewed this question
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
