Question about Dell UltraSharp 2000FP 20.1" Flat Panel LCD Monitor
Flickers and Lines
Just got one of these used from a friend. There is a vertical white line about an inch thick that runs the length of the screen (Top to Bottom). Also, the whole screen flickers with lines. Is there a cost effective way to fix or is it junk?
  • 55 Answers
You have the vertical circuit "closed" you have to repair it checking
transistors and capacitors . if you can  it this work may be at low cost - few dollars
Posted on Mar 21, 2008
Vetical lines on monitor
The LCD panel if failing, you will get more line as time goes by due to bad LCD t-con board (part of LCD panel). Nothing you can do but replacing the LCD panel.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
http://s807.photobucket.com/home/budm/allalbums
Apr 17, 2010 | Acer AL1916W 19" LCD Monitor
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
My dell e196fp lcd monitor has white lines
Dell had a problem with horizontal lines in some of their monitors a little while back. I would try contacting Dell Tech Support to see if your monitor is one of the one effected. I think they were replacing the monitors that had the problem, but I'm not completely sure.
Mar 15, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
Monitor
capacitor (either ceramic or electrolitic) that connect to vertical ic (TDA8173 or TDA 9302) is short or open. Check all capacitor in vertical range. tq
Nov 22, 2007 | IBM E74 17" CRT Monitor
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Vertical lines in my laptop screen
Although it could be a screen problem, it is more likely either a loose connection on the inside of the LCD or the video inverter itself which is a board that the LCD attaches to before going to the motherboard. Try hooking it up to an external monitor and if it doesn't do it on that, then we know its not the video card / video output. After that it would be what I spoke of above.
Jun 09, 2007 | Compaq TFT500 (White) 15" LCD Monitor
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Dell UltraSharp 2000FP 20.1" Flat Panel LCD Monitor Logo
261 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
