Question about SanDisk Sansa e260 MP3 Player
Mp3 player how do u reboot the player
    Problem Solver:
  • 5 Answers
Press the on/off button for 10 secondes sometimes is 12-13 but it gonna go off
Posted on Mar 25, 2008
Mp3 player is recognised by the computer but the mp3 player wont turn on
First, make sure that the MP3 player's (internal) battery is fully charged. Then unplug it (the MP3 player) from the power source and try to power it up. For some MP3 players, you may have to hold down the "power on/off" button down for a few seconds ... or lots more ... until it reboots (light up) and start up.
Nov 04, 2013 | Audio Players & Recorders
Player just went off and will turn on, how to reboot?
Having gone over a month without a response, I assume the suggest reboot solved the problem.
Aug 16, 2010 | SanDisk Sansa e260 MP3 Player
Mp3 player
~~shove it up your *** or something that might help! or deep throat it down your ugly hairy mouth you ******~~
Aug 11, 2008 | iRiver E10 Digital Media Player
I unlplugged my mp3 without removing it safely and now its stuck on a message that says please connect player to PC. and i did and it doesnt reconize it.
Unplug your mp3 player again and reboot your computer. Once windows fully loads plug your player back in and it should recognize it. If your player won't recognize at that point run windows update and download all the latest updates and reboot again.
Also, try plugging it in to a different usb port on your computer (somtime that works for me)
Jul 16, 2008 | Audio Players & Recorders
Gone crazy
Reboot the MP3 or go get a Zune if the MP3 won't work anymore.
Mar 18, 2008 | Nefertech Diamond MP3 Player
Creative vision m
you should not have had to install anything for the Zen to work on Vista. If you have installed any Creative software, remove it. Reboot, plug your player in, open Device Manager, and remove the device that shows up representing your player (completely uninstall it). Reboot again, and plug in your player. It should be recognized now.
If that still doesn't work, then boot your player into Recovery Mode, and perform both a Disk Cleanup and a Reformat. Reboot the player and try plugging it in again.
if it still doesn't try another computer and upload the latest firmware to it and then try it on your pc after firmware is loaded
Jan 13, 2008 | Creative Labs Zen Touch MP3 Player
Ipod 30 gb
Jan 13, 2008 | Apple iPod MA446LL/A MP3 Player
My mp3 player is having a nervous breakdown
I found this from themp3players.com forum: http://www.themp3players.com/archives/2006/10/firmware-fix-for-siren-ilo-mp3-player/#more-387 looks like others may have had the same problem.
Aug 08, 2007 | iLO MP3 Player
Frozen MP3 Player
There's a reset hole by the side of the player. Try reseting it. It can freeze sometimes, and fix itself after a while. no apparent reason. reset, run the battery down and recharge. Hope it helps. this is from the creative site: The recovery mode consists of these four operations. * Clean Up: It is the least destructive operation. It scans a player's hard disk and removes any invalid links from the music library. It does not affect music files themselves. It is recommended that you perform "Clean Up" first before formatting or reloading the player's firmware. It is recommended that you clean up regularly if you frequently transfer files between a PC and your player. * Format All: It is the same as a Windows format performed in a PC, and consequently all contents will be lost after a format. * Reload Firmware: Reloads the player's firmware (Operating System). It will also format the player. Note : It requires the player be connected to a PC that meets the player's minimum system requirement. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install. * Reboot: Reboots the player. You can reboot the player after performing a clean-up or format, or reboot it without performing neither of them. It is recommended that you try these operations in the following sequence: reboot the player; clean up and reboot; format and reboot; and finally, reload the player's firmware. If your player seems to stuck in the recovery (rescue) mode, you can try the "reboot" operation first, and format the player if necessary. If it fails to reboot, you will need to connect the player to a PC, and reinstall its firmware. For a detailed instructions on how to install a player's firmware, please refer to Updating the firmware on a Creative MP3 player, or refer to the Web Release note of the firmware download. Unlike other hard disk based players, Zen Neeon does not have a rescue mode. Though there is a Player Recovery Mode , it is for use when updating its firmware only. 1. Detach your player from your PC , and ensure that it is turned off. 2. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications. 3. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe. 4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen. 5. Hold down the Play/Pause button while connecting the player to a PC's USB port. 6. When the Creative logo appears on its screen, release the Play/Pause button. The player is now in Player Recovery Mode.
May 19, 2006 | Creative Labs Zen Neeon MP3 Player
SanDisk Sansa e260 MP3 Player Logo
16 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
