Question about JVC DR-M1 DVD Recorder
Machine keeps cutting out. When I switch it back on its says loading then cuts out again.
Change all the electrolytic capacitors in the power supply and IC5101
Posted on Nov 11, 2008
Keeps tripping power at 13minutes remaining, just before the spin cycle
Hello. It sounds like the motor has gone bad--possibly a shorted part of the motor, or a jammed drain pump. It also could be the transmission binding at the point of going into spin mode. You didn't provide a brand/model number so my help is limited. The clue here is the clicking before the power trip.
Aug 19, 2015 | Washing Machines
Beko wm5121w 5 kg keeps cutting out the electrics can open the door machine starts to fill and eveything cuts out
With the machine unplugged, try disconnecting the heater and then turn the machine back on. If it is still tripping the electrics reconnect the heater and disconnect the motor, then turn on again. Likely one of those is causing the fault
Mar 12, 2014 | Washing Machines
The machine keeps cutting out in the middle of the
hi,i think its due for service so you have to take it to the company you purchased it from or you check if nothing is stuck in the machine that blocking the passage of water,or you also call an electrician to help you check your electricals on the wall or the one connecting to the machine.thanks.will really appreciate your understanding.
Mar 08, 2010 | AT&T Siemens S46 GSM Cellular Phone
Pressure washer keeps cutting out
Carb problems: needle seat is sticking!
Dec 08, 2009 | Garden
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Water won't cut off on super load
yes raise your drain hose up. do not shove it down the drain to far or the bottom of the hose will be below the water level in the machine. it is called siphoing. you can hear it by shutting the machine off when it is at the cycle you stated and hear it draining. pull the hose up and secure with a strap.
May 17, 2009 | Washing Machines
My dishwasher when switched on keeps throwing the trip switch
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Oct 09, 2007 | Indesit 24 in. D63 Free-standing...
JVC DR-M1 DVD Recorder Logo
175 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
