My computer continuously restart - Computers & Internet
  • Anonymous Mar 03, 2009
    i recently played a movie from my cd drive ,i got an error titled media controll.exe.iclicked ok to terminate the program.from then on my pc starts,turns to blue death screen and restarts continously
    Scholar:
  • 117 Answers
Ok....first off
1. Is your computer a laptop or desktop
2. Which operating system are you running
3. When did this start happening and what were you doing last?
Please let me know so that I can further help you..
Thanks
~~Jasta~~
Posted on Mar 21, 2008
    President:
  • 2,351 Answers
Hi jfb1407, your windows files are corrupted. Please reinstall your windows operating system. Load your windows CD in to your cdrom drive. As your PC begins to start up press the F8 key every 2 seconds until window boot menu loads. Using your keyboards up & down arrow keys move to highlite your cdrom drive & press enter. Windows should begain to load. You wil see on your screen, Press any key to start from CD...... Press any key. Windows will begin to load, follow the on screen instructions. You want to repair windows. Do not try to recover windows (it will fail). All your personal data will not be erased. Some other programs might need to be re-installed. (not a big deal). When windows has finished you'll need to update windows through, Windows update.
Good Luck & take your time.
Mike
Posted on Mar 31, 2008
    President:
  • 1,017 Answers
It's probably caused by your CPU overheating, there's a protective device designed to protect your PC if the CPU gets too hot. You could try gently brushing the dust around the fan, while using a vacum cleaner to suck in the dust. If that does'nt work you need to disconnect the fan from the CPU and put a very thin and even film of heat sink. Running temperature is approx. 45c/113f
    Genius:
  • 1,913 Answers
Check your ram try onther ram
check your power cable , supply , smps step bye step
check that board dont toch the cabinet means ground.
also scan your system with anti virus like avast, quick heal and symantec with update definition
if u gor problem then format your parttion and install new window xp.
Continually restarts and won't turn off. Performed soft restart and continuously restarts.
If this is a computer, what happens when you unplug it and plug it back in?
Apr 08, 2017 | Computers & Internet
Resized c drive, now windows won't start. How can I reinstall windows from windows disc
Hi Terrez,
  1. To reinstall windows from Windows disk Insert the disk in the drive, restart the computer and enter the BIOS setup.
  2. In BIOS setup, make the DVD Drive the first-starting device.
  3. Save and exit BIOS setup.
  4. Now the computer continues the restart. Look at the screen. When a message appears, you have only a few seconds to hit any key on the keyboard in orter to start the computer from the disk.
  5. From there, Windows setup will continue.
Feb 24, 2013 | Acer Aspire 3680-2682 Notebook
To continue working where you left off, please restart Audition.
To continue working where you left off, please restart Audition, then I received the "Run Time Error" msge. Restarting did not work, however, re-installing worked perfect.
May 25, 2012 | Adobe Audition 3.0 Full Version for PC
My pc will restart itself ..... but when i play games it wont restart ...i already turn off auto restart.... change the power supply to 500watts... but when i surf the net it will restart suddenly but...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Apr 05, 2011 | Computers & Internet
THERE'S GOT TO BE A SOLUTION TO MY LAPTOP PROBLEM,I KEEP GETTING THIS MESSAGE, "THE COMPUTER RESTARTED UNEXPECTEDLY OR AN UNEXPECTED ERROR. WINDOWS INSTALLATION CANNOT PROCEED TO INSTALL WINDOWS,...
The problem is caused by a damaged Windows installation CD.
There are some files that cannot be read from CD, so Windows gets stuck.
It tries to restart to continue with installation, and keeps doing this on an endless loop.
Solution:
Get a goos Windows Installation CD and start from scratch, (format and load the new copy of Windows)
Don't forget to rate this answer if it helps.
Jan 27, 2011 | Everex StepNote VA4300M Notebook PC
Computer never continue to start up, it just continue restarting at least 2 times then it hang. when i try to reboot monitor never display any images anymore and what i noticed when that happens is that...
run it in safemode with networking and install safemsi.exe and then run malawarebytes which is free to download ,update it and run this will fix the problem
May 08, 2009 | Microsoft Windows XP Professional for PC
Computer is not starting up in standard windows mode. dell media keeps popping up and when i exit the program my pc shuts down. i tried ctrl and f8 it brings me to a short menu. (1) continue restart...
Are you running Window XP? Is your computer set to hibernate? If so, you may have a hibernation error...
If I understand correctly, while pressing F8 during bootup you received a message that states:
"System restart has been paused:
Continue with system restart.
Delete restoration data and proceed to system boot menu"
You may wish to read this article about the error. http://support.microsoft.com/kb/294427
Then, go ahead and do that second option. What hibernate does is write a big file to the HD with the exact state of Windows. That is a "restoration" file. If hibernate doesn't work, deleting the restoration file will often allow the computer to restart normally.
Good luck! Please post back with your results.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Dell Inspiron 1420 Notebook
Won't sweep
you may need to manually update the program by going to the Options tab and click Update. If you receive a dialog box stating, "Continue, Shut Down, Restart Program" or something of the sort, click Continue using Program and it will update the definitions. then restart computer and sweep. If this doesn't work then your program may need to be reinstalled with a valid subscription key.
Jun 28, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Scanner comes on automatically at computer startup
I would suspect that you have something else attached to your computer that is causing the scanner to react.
Disconnect the USB cable from the scanner and restart the computer. After the computer has fully restarted, connect the USB cable to the scanner. The scanner may initialize at this point. If after 30 seconds the scanner continues to cycle as you described, the that is an indication that there is something that is actively pinging the USB ports causing the scanner to react. If the scanner doesn't continue cycling, then reboot the computer and see if it does it again upon bootup.
Assuming that the scanner continues recycling:
Disconnect all USB devices (except the scanner) from the computer and then restart. If the problem goes away, then one of those devices is the culprit. Connect them one at a time, rebooting each time, to determine which devices is causing the problem. Once you determine the cause, then you'll know where to go for help.
Hope this helps.
Jun 11, 2008 | Canon CanoScan 3000F Flatbed Scanner
Computer restarts when I plug in canoscan lide 60
uhh.! if you install the scanner.! the computer really have to restart so yo can continue to scan ur pics.!
Feb 29, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Computers & Internet Logo
377 people viewed this question
David Payne
David Payne
