Electric shower ive recently had an electric shower fitted and there was hardly any water coming out of it and it was cold and wouldn't get any hotter now there's still hardly any water coming out and its piping hot then cuts out and does it all over again.
  • 97 Answers
Water pressure not sufficient
Posted on Mar 21, 2008
SOURCE:
I have a moen shower faucet where the water mixture keeps getting hotter with very little cold coming through. the temp must be set nearly all the way to cold to prevent scalding.
Sounds like a pressure-balance shower valve. The pressure balance cylinder is stuck. With water off, remove knob and trim plate. Remove pressure balance cylinder (horizontal). May be hard to get out. Use emory paper to clean up cylinder and smooth it so it moves freely. Reassemble and you'll be happy.
May 28, 2017 | Moen Home
Hi, is there a way to make the hot water hotter in a 2016 Jayco Journey. The water is just hot enough for showering but not hot enough to wash the dishes.
remove the unit that mixes the hot and cold water at the hot water system to prevent scalding of people
it is fitted there by law but unfortunately the plumbers who fit it are not willing to fit it where it is supposed to be fitted ( baths , showers and hand basin taps and lines )
better and cheaper to fit just one than several
it is not required for sinks and dishwasher and washing machines lines
anyway the human hand cannot stand water over 75 c as that when burns occur so having hotter means that you have to add cold to be able to put your hands in the water and that sort of defeats the purpose of having hotter water
Apr 05, 2017 | Home
I have a bristan 8.5kw electric shower, temp fluctuated to very hot, then to very cold. Now only cold. I had a combi boiler fitted now the shower seems broken, does this have any relevance to the flu
Changing the heating system will not affect an electric shower as it is run from the cold water supply,sound like the temp thermostat has blown ,contact bristan or there website to get a replacement thermostat,telling them which model electric showrr you have.
Sep 13, 2017 | Home
Theres only a low flow of water coming out of the shower.
remove the head and make sure you have a good flow to the head if you do look to see if a plug needed to be removed before installation if their isn't return the product
Jul 06, 2012 | Home
Have triton ivory electric shower but flow rate is rubbish when set to 7 or 8 too make water hotter why?
How cold is the water coming into the heater?
How long has it been in use?
Do you have 'Hard' water?
It sounds like a scaling, and flow restriction problem--
Tell us more what you are trying to do, and what you are working with-- (as far as water, hardness, pressure, age, etc.)
Dec 27, 2010 | Heating & Cooling
Triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
Dec 01, 2008 | Home
Fitting Electrical Shower -electrician will do final connection at consumer unit
Sorry,
Thought the service was free
Silly me, only found out it wasnot after I had typed the questioin and thought it would then be aired on the forum anyway
Thanks anyway,
Roger
Jul 31, 2008 | Kitchen Appliances - Others
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
