Question about Garmin Nuvi 660 GPS Receiver
Sd card how do I get the garmin nuvi 200 gps to interact with an sd card?
  • Garmin Master
  • 638 Answers
Insert the SD card into the slot on the left side of the unit.
Posted on Sep 29, 2008
Garmin nuvi 200 SD card
Did you rename the file extensions? On the unit, the map file and map unlock file must be named gmapprom.img and gmapprom.unl
On the SD card they must be named gmapsupp.img and gmapsupp.unl.
Also copy your garmindevice.xml file over to the SD card too.
Feb 26, 2013 | Garmin nuvi 200W GPS Receiver
Want to update maps
Yes, you will need to download the webupdater program from Garmin to get new maps for your Nuvi 200. Transfer the files to your SD memory card and then plug that SD card into your Nuvi 200. Click on the link below to get started
http://www8.garmin.com/support/collection.jsp?product=010-00621-10
May 16, 2010 | Garmin nuvi 200W GPS Receiver
Lost the information card
Garmin.com should have anything you need to help you get going. You can download map updates or new maps altogether and save them to an SD card to load onto the device. You should be entitled to one free map update with your new device if you have not taken it yet. You can also download manuals as well; their website is pretty loaded with information and I have had good luck dealing with them.
Aug 30, 2009 | Garmin nuvi 200W GPS Receiver
I have a Garmin Nuvi 200 and cannot load 2010 update
Install the SD Card. When you select your maps and transfer them to the device, make sure the Nuvi is plugged into the USB. When you are on the screen to "Find Device", select the dropdown menu and you should see the drive letter referencing your SD card. Select that and you should be all set.
Jul 17, 2009 | Garmin nuvi 205W GPS Receiver
Garmin Nuvi 200 Maps Disappeared
Hope this helps!
I wanted to add maps to my 250W. I found the maps I wanted on a Torrent. However, many searches around various forums never revealed how to install these. Found the following through reading and experimentation.
1. Downoaded map image file GMAPSUPP.IMG. Download also gave me "Use code XXX when generating unlock code for maps"
2. Downloaded Garmin Unlock Generator 1.3 by JetMouse
3. Looked on my GPS to find the UnitID
4. Entered the UnitID into Garmin Unlock Generator. Ignore the GM XT device unlock code and the top Generate button.
5. Selected Map Product as Custom and entered the code given for the downloaded image file.
6. Hit the bottom create button to generate a 25 digit code.
7. Download Img2Gps and run
8. Click Load Folder to load the image file. Select the tick next to it.
9. Check the Use Unlock Key option and paste the 25 digit code in.
10. Load a blank SD card into your Garmin
11. Connect the Garmin to your PC using a USB cable. You should see two dirves in windows: one is the Garmin and the other is the "Removable Disk" SD card.
12. Create a folder called "Garmin" on the SD card
13. Select Folder/Card in Img2GPS
14. Click "Copy Maps". Select the folder /Garmin on the SD card. You may need to click copy again.
15. Upload will take a while.
16. You should now see a file GMAPSUPP.IMG on the SD card in the /Garmin directory.
17. Create a new text file called GMAPSUPP.UNL in the same directory (make sure it does not have a hidden .txt extension).
18 copy the 25 digit unlock key into this file.
19. Close the file.
20. Disconnect the Garmin.
21. On Startup it should load your original maps and the new ones.
May 28, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
How do youcess your sd card on the garmin nuvi 200w series please
i lost my card for my garmin nuvi 200w series do i really need it
Mar 21, 2009 | Garmin nuvi 200W GPS Receiver
Nuvi 200
Insert your card with your JPEG picture only and you can read it.
You can also plug your usb and go to your computer , open the file GARMIN you will see many files , do not touch the GARMIN main files who include your charts and other important files but the others are there for the users. Copy and paste your picture into the one who already has picture from GARMIN.
Or copy into a SD card and read it on your NUVI 200 or 200W.
Best regards
Jan 04, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
404 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
