Question about RIM BlackBerry 7290
Error Screen when turned on
When I try and turn on my Blackberry 7290, it stays at a screen that looks something like this: a rectangle made to look like a browser/appplication window, inside are three shapes - a circle, square, and triangle, all around the entire browser/application window its got a circle with a line through it and lastly, below it its got the number 507 written underneath it.
I can't access my phone at all and I need to know what the problem is. The manual I've been reading online do not give me any clue whatsoever as to what this error could mean.
  • 1 more comment
  • lordbigoth Mar 24, 2008
    hi im tristan from the philippines. my bb 6710 is working abnormal it always shows an hour glass sign on the screen everytime i do an action such as scrolling the rollers or just simply by clicking the keys and now i could not use my phone anymore to text or call because i'll have to wait for sometime before it response, my bb is only 1 yr old. i already opened and clean all the dust and have it reset by removing batteries for a few days and also used the reset button at the back but still not working normal. can you pls give me some tips to resolved this problem i really like this phone thanks.
  • rossolarnold Apr 08, 2008
    yes I've got the same problem stated above. before I having this problem my phone went off automatically several times a day and sometimes I did experience another problem. My phone was searching for network and most of the time of a day it used to stay out of network showing a sign on right of the top of the screen in network tree a cross sign. After continuing this problem for couple of weeks it showed a message asking for reset and device error 373 for 2/3 days and now finally its showing the above stated message error 507 and now I can't totally get in my phone.
    Please help me to resolve it.
    thank you.
  • mr_magpiegom Feb 24, 2009
    error 7290
  • 103 Answers
You need to reinstall the reinstall the phones firmware. Go HERE to download the firmware.
Posted on Sep 29, 2009
SOURCE:
Phone will not turn on screen says device error 377
you will likely need to wipe your device using JL_CMDER and then reload your operating system
also try this link
http://crackberry.com/blackberry-101-lecture-12-how-reload-operating-system-nuked-blackberry
Apr 07, 2010 | RIM BlackBerry 7290
My Blackberry 7290 won't turn on
Hi, The BlackBerry device is unable to complete the initialization process, the Device Error 365 Restart error occurs To resolve this problem, you need to follow the steps below: Attempt to run Application Loader. Application Loader will remove the BlackBerry Device Software (both the operating system and Java applications) completely and reload it.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
Blackberry 7290 device error 400 how solve this problem
When adding, deleting, or updating applications on your BlackBerry smartphone, your BlackBerry device resets itself and stops responding.You receive the following error message:
Device error 400
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Nov 01, 2009 | RIM BlackBerry 7290
Solution for 7290 blackerry frezzes up how do i reset?
Try resetting the phone by powering off, removing the battery leaving for 30 seconds reinserting the battery and powering on.
If that doesn't work hold down ALT+RIGHT SHIFT(CAP)+DELETE keys simultaneously unti you get a blank screen.
May 11, 2009 | RIM BlackBerry 7290
Error message on my phone screen , asking me to reset and nothing happens when i press r which stands for reset
go to the BB website, select your phone (7290), download a new OS (V4.1 or something) enter service provider and info, download to you desktop, install on your computer, open BB desktop manager, push the trackwheel in to select reset, then quickly connect the cable to your computer, open up install applications, click next, and follow the instructions. thats it.
May 06, 2009 | RIM BlackBerry 7290
Blackberry Says Error 322 Reset
Try a new battery. This is usually due to a bad or old battery that can't hold the charge properly.
Apr 10, 2009 | RIM BlackBerry 7290
Blackberry 7290 device error:373 reset
Hi Anand
Practically speaking i spent 3 hours looking for your solution but nothing much even the BB intelectuals failed .Try these steps out it may resolve the issue and lets hope for the best .
This error : 373 : Device Error means that the Timers are corroupted
1. Remove the battery for at least 5 minute.
2. Make sure u have working SIM card, other wise remove the old SIM.
3.You should receive an Hour glass spinning. Give a few minutes, after that u will see a 507 message on the bb screen, (which means there is no app loaded on the bb)
4.If this dosent work
Use application loader to wipe handheld clean and reinstall base software but do backup your data
And please let me know .
Apr 04, 2009 | RIM BlackBerry 7290
My blackberry 7290 Rim(T-Mobile)says: Device error
An unspecified error has occurred with an application on your Blackberry smartphone.
Resolution In BlackBerry Desktop Manager, run the BlackBerry Application Loader tool.
Note: The following procedure will delete all data and applications from your BlackBerry smartphone.
    1. Remove the battery cover.
    2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
    3. Replace the battery cover.
    To perform a hard reset on a RIM 850 device, RIM 857 device, RIM 950 device, or RIM 957 device, insert the end of a paperclip inside the small hole on the back of the BlackBerry device.
  6. Click Next.
Mar 01, 2009 | RIM BlackBerry 7290
Have you tried to remove the battery and then restart the phone?
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
Nov 11, 2008 | RIM BlackBerry 7290
Blackberry not on Home screen
did you try and redownload software?
Sep 11, 2007 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
104 people viewed this question
Top RIM Computers & Internet Experts
Ekse
Vincent G
Vincent G
ChrisChris70
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
