Cd drive (D)
It has stoped working i put a cd rom in and works for a few seconds then stops nothing its a 48x max on a dell pc. it will sometimes work on my pic cd's but tried looking at a pc advisor cd rom and nothing. can i get a new one and is it easy to install?
thanks
    Novelist:
  • 155 Answers
CD/DVD drives are one of the most common things to fail on a PC, but also one of the easiest things to change! And they're very cheap too!
To change a drive, this si what you need to do:
Turn off your machine & unplug from the mains.
So you don't sue me, I'd recommend you wear an earthing wristband to prevent possible static discharge damage to any components. (In reality, if you're only changing a drive the chances of damage are absolutely tiny.)
Open the case.
Unscrew and unplug the old drive.
Fit the new drive and plug it in.
Put everything back together, power on and off you go.
Simple as that!
The only thing you will need to check is the type of connection your existing drive uses. There are 2 types: IDE and SATA.
If you have a big, about 2 inches wide, flat ribbon cable going into the back of your drive, it's IDE.
If not, it's SATA.
(Both will have the same type of power connector)
Just make sure that the new drive you purchase is the right type (IDE or SATA)
Hope this helps,
Matt
Posted on Mar 21, 2008
SOURCE:
Cd drive not working
Try cleaning the head with a burst of clean air from a compressor. Be careful not use air with oil or water mixed into it. Sometimes, with the mere blowing of air from your mouth would clean the lens.
Mar 12, 2014 | Sony DDU-1615 / 16x DVD-ROM / 48x CD-ROM /...
HELP MY COMPUTER WONT READ ANY CD'S EXCEPT A DVD,, WHAT IS THE PROBLEM?? ANY HELP
hi
you have either one of these ..
5187-5619 = DVD-ROM/CD-RW combination drive - 48X CD-R write, 32X CD-RW rewrite, 48X CD-ROM read, 16X DVD-ROM read
EL436-69001 = 48X DVD-ROM CD-R/RW optical drive - 48X read, 32X read, 48X read, 16X max write speed
make sure you buy CDs or DVDs which are speed compatible to your optical drive or COMBO drive speeds
if you are busying compatible speed CD media, then take some compressed air (can) and clean the drive bay and inside the optical drive area, to dedust it .
go to this site and review all the related sites .. read carefully and try to figure out what the possibility (issue) is .
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=15887&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=431075
if ALL this fails, you may have to replace the DRIVE itself
i hope this helps
Nov 08, 2010 | HP Pavilion a705w PC Desktop
Does this have a cdrom?
YES, it has a 48x CD ROM drive.
It is not a burner.
You can play music read data from the CD, but you cannot burn CD's or DVD's.
Here is more information from EMachines:
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T1090
Oct 02, 2009 | E-Machines T1090 PC Desktop
Emachine EL1200 won't burn dvd's.
I researched the Emachine EL1200 and it IS equipped with a DVD burner so there is no reason it shouldn't work. Return it while it is still under warranty. There is a 1 year warranty.
If it is out of warranty (system is older than 1 year), the drive can be replaced.
Aug 15, 2009 | E-Machines emachines (emachinees) CD-ROM...
What type blank CD is compatible with 48X CD-RW/DVD combo drive
the cd u need to buy is cdr
and is your cd rom a cd rewriter?
good luck
hope i was a help
Mar 22, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
CD/DVD rom drive not working
Hi there.
It sounds like the drivers could be bad or the lens has gone.
This can be a common problem with vista loosing the CD/DVD drives.
Do this >>>>>> right click on "computer" and select "manage" from the sub menu, then select "device manager" from the left hand side, it will generate a list of devices, look down the list for CD/DVD and click on the + icon next to it, from the drop down list right click and uninstall, restart the PC and let vista re-install the drivers for you, then try to use the CD/DVD.
If this does not work please post back.
Good luck and thanks for using FixYa!!
Mar 16, 2009 | Dell Inspiron E1405 Notebook
Pc died
Hello, I have had similar problems with that same motherboard in the past and have found that resetting the cmos (see users manual) or just taking the battery of the motherboard for a few minutes can solve this. CAUTION please remove the power lead on your tower before touching any components inside, and earth yourself first by touching metal.. as static discharge kills pc components..
Hope this helps.....
Tony.
Sep 09, 2008 | ASUS K8N4-E Deluxe Motherboard
Cd-rom drive
try to separate the ide cable. /
Feb 08, 2008 | Computers & Internet
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Open Questions:
    Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}Avg TeCh SuPpoRT pHoNe @{+1^888499*5520~}
    Oct 16, 2019 | AVG Computers & Internet
    Computers & Internet Logo
    127 people viewed this question
    Ekse
    Alun Cox
