Question about CyberLink PowerProducer 2 for PC
File loading error
Hi guys,
I dont really know the version of cyberlink powerproducer i am using. Of recent, when i try to open it, it gives the error "File loading error". I dont know maybe i have mistakenly deleted some important files on the system. I need your help.
    Genius:
  • 1,913 Answers
No dear
it is just come with cyberlink power dvd and burner setup
reinstall it and theb remove it it is not any sys file ok
bye
Posted on Mar 24, 2008
SOURCE:
I just installed cyberlink powerproducer 2 gold (2-8-11) on my comp.(medion 64 bit vista) when first attempted an installation,an error message opened stating "this program is intended for windows 98...
can u send me a .iso of program?... I can't found that anywhere... u can write me in lgchot<at>hotmail(dot)com thank you very much for help me... luc
Feb 08, 2011 | CyberLink PowerProducer 2 for PC
Burning DVD's
What burner are you using? if your burner is a DVD -RW and using +RW media, you might have a situation there. Check your media vs device.
Dec 13, 2007 | CyberLink PowerProducer 2 for PC
I have been using Cyberlink Powerproducer Express for many years which after producing the appropraye files, it passes down to and opens Cyberlink - Power Producer 2 Gold to generate the DVD. For some...
If recently you have made any hardware or software changes eliminate that and then check how it works.
Do system Restore to a previous date when your computer was working fine to do that go to Start - all programs - accesories - system tools - system restore select a date when your computer was working fine follow the on screen steps.
if you have win vista then start-search type system restore and do the same thing.
If this doesnt helps try to uninstall and reinstall the software.
Jul 25, 2010 | CyberLink PowerProducer 2 for PC
The version does not support the disc type or the disc utility or function, some video files in the project do ot exist . This is strange as I have viewed them before. Now I cannot open any of my family...
I am not sure but you can try VLC player.
VLC Player supports almost every file format and all types of video codec.
I hope it works for you.
Cheers
Oct 30, 2009 | CyberLink PowerProducer 2 for PC
Have lost my Cyberlink PowerProducer Gold, how can I get it back?
Go Start>My Computer
Double left-click on Local Disk C:
Double left-click on Program Files
Look for folders named "Cyberlink"
Let me know what you find
Oct 14, 2009 | CyberLink PowerProducer 2 for PC
Failure while importing videos
is it because i dont got the original version? so i can't import videos with more than 30min?
thank you
Apr 28, 2009 | CyberLink PowerProducer 2 for PC
PowerProducer3 'failed to add video file'
I solved this problem by using a different program as I could not resolve the error with the cyberlink software.
Sep 09, 2008 | CyberLink PowerProducer 2 for PC
Video file not readable today, but was yesterday
Give this a try
Make a copy of the file and rename the .ppp to a standard ".extention" for the file.
Oct 25, 2007 | CyberLink PowerProducer 2 for PC
Failed to launch PowerProducer Project
I had the same problem and after troubleshooting found out that the project was not opening because I had changed the location of some pictures I used on a slideshow.
It sucks that the project doesn't have it's own version of the slides and requires the photo files to be in the same physical location as they were when you originally created the slide or used the video file.
Not sure if this will help others, but if you moved any files that you used to create your project, try to restore them to their original location and see that fixes it for you...that fixed my problem.
good luck.
Oct 08, 2007 | JVC Everio GZ-MC200 Camcorder
I have audio but no visual
hi chunklebutt, Sounds like maybe you do not have the correct codecs on your system? or your application does not support the type of video you are trying to load. If you are trying to use an AVI, try the gspot codec application (www.headbands.com/gspot) and see if you can figure out what codecs you may need. Let us know if this helps, or if you are still running into problems. Good Luck!
Jul 26, 2007 | CyberLink PowerProducer 2 for PC
CyberLink PowerProducer 2 for PC Logo
236 people viewed this question
Top CyberLink Computers & Internet Experts
Alli Abiola
Alli Abiola
Peter Dragonetti
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
