Question about Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover F7425-900 How to attach hand held cleaner
I have lost my manual. Can you tell me how to attach the hand held unit for furniture?
  • Donna Price Cady Mar 30, 2008
    Thank you. I did finally find a manual and downloaded. I appreciate your help.
  • Anonymous Mar 26, 2014
    Must recharge too often
The suction is not all going to the hand held- some is still going to the floor part----- any solutions?
Posted on Mar 30, 2008
  • 126 Answers
There is a round door at the top/front of the clear duct on the hood of the unit. You insert the hose there and then connect the small solution hose to a valve that is located on the right side (if you are facing the machine) of the machine, just ahead of the rear wheel.
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Lost manual. How do i hook up the suction part of the furniture upholstery attachment? I know where to plug it in to spray cleaner on the furniture but where does it plug in to **** it up? Model...
on the attachment where you put the attachment remove the lid, then remove the back panal, and slide the suction thing down not much pressure, re apply the lid then put back in vacuum, turn on and there you go...
Sep 02, 2011 | Hoover F5906-900 Upright Steam Vacuum
Attach furniture/stair cleaner ?
Please look at the user manual at the following link:
http://www.hoover.com/pdfs/manuals/F5871900.pdf
It is for a similar Hoover Steam Vac model.
Oct 30, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
MY hoover steam vac hand held hose cleaner leaks profusely
try taking a sharp knife and shaving a little off the edge of the plastic, or a small file if you can get to it, see if it is getting binded. If its getting stuck internally, you will have to replace the switch instead of risking takin it apart.
Jul 09, 2009 | Hoover F5810 SteamVac Upright Vacuum
I need yo find out hoe to use the upholstry attachment. Ilost my
I'm not quite sure where the attachment plugs in but, I did find an owner's manual for this Hoover online.
http://www.hoover.com/pdfs/manuals/F5918900.pdf
I hope that helps. Good luck!
May 25, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover steam vac
  1. Remove your cleaning solution tank and set aside.
  2. Remove the lid to your recovery tank.
  3. Remove the front panel of the recovery tank by sliding it straight up.
  4. Slide the convertor half way down into the same slot. (Curved side down). The opening should be facing upward.
  5. Replace the recovery tank lid.
  6. Open the door marked stair/upholstery cleaning connection.
  7. Press the tube connector with the black tabs onto the projection inside the door.
  8. Replace you cleaning solution tank and you are ready to go.
Note: It's a good idea to turn your brushes off. Also, you may need to prime your hose by turning on your cleaner and holding the hand tool onto a flat surface for a few moments before use.
Aug 08, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
How to hook the parts for cleaning furniture
How to Clean Wooden furniture The tips below explain how to clean wooden furniture, but an essential part of everyday maintenance is to place protective mats or pads under them to prevent the wood from scratching - otherwise, your efforts will be in vain.
  • If you're wondering how to clean wooden furniture on the regular without much hassle, regardless of the wood finishing, you should get rid of the dust first.
  • Make sure to attach a dusting brush to your vacuum cleaner to remove the dust on your wooden furniture to avoid scratching it. If you do not have a dusting brush attachment, opt for a soft microfiber cloth instead.
  • Then apply a specialized wood cleaning product - always follow the instructions on the label, and choose your product to suit the finish on your furniture. Read on to find out which to use
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Jun 17, 2008 | Vacuums
Using upholstery attachment on the hoover spin scrup heated cleaner
I had the same problem. Instead of wasting time/energy I could use cleaning the furniture, I decide to look online for a manual instead. I hope this helps. It helped me!! http://hoover.com/pdfs/manuals/F5914900.pdf Good Luck !!
Sep 08, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum Logo
162 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
