Question about Whirlpool GEW9250 Electric Dryer
Whirpool duet dryer quit working
Hi. My dryer is a whirlpool duet. I have had it since December 2005. The lights on the panel work, but the drum does not turn and motor does not run. The sensor lights go from sensing to wet to all the way through the cycle, and the timer counts down..and the buzzer goes off saying it is done, but the drum does not turn and I do not notice any heat. What would cause this? I did notice that the drum seems awfully easy to turn compared to normal....
I did try unplugging the power to reset it and this made no difference. Thank you for any advise you might have.
  • Anonymous Mar 31, 2014
    The machine quit in mid-cycle. The light panel works, but the drum does not spin, and when I turn it by hand it is very difficult.
  • 156 Answers
Chould be a fuse inside dryer its oblong white ck it but unplug dryer first
Posted on Mar 21, 2008
SOURCE:
My whirlpool duet electric dryer electrical systems and heat work fine, but drum won't turn and belt is in tact.
Check the motor capacitor,sometimes the capacitor could be faulty or the motor is faulty or check if the motor is receiving power,if it's receiving power try to replace the capacitor if the is any in the system,if still it's not working then the motor could be burnt.
Also check weather the timer is perfecty.
Sep 29, 2012 | Whirlpool Duet High Efficiency Electric...
Whirlpool duet gas dryer is not working. The lights on the control panel are on. My husband has replaced the thermal fuse, thermistor and the motor. Still will not run. Please help.
check the door switch,if this switch is bad dryer wont work,this is a spdt type switch as it runs the drum light when doors open and lets machine start and operate with door closed
May 06, 2012 | Whirlpool Dryers
Our Whirlpool Front LOADER WILL not start. All the lights on the front panels are but the drum will not turn. I have repalced the main control panel under the top of the drum.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My Whirlpool Duet Sport dryer will turn on, light up, and make a 'click sound" but the drum then will not turn
heatman101
Jul 12, 2011 | Dryers
My whirlpool dryer front loading wont turn the drum i change the control board but still wont work .
did you check the belt to see if it's broke,the belt raps around the drum and the motor,when the motor turns on and spins the belt spins the drum.
Mar 28, 2011 | Whirlpool Duet Front Loading Dryer Rack...
The dryer makes a new noise now when the drum is turning. It is a steady "tick -- tick -- tick -- tick --etc" which is laid over the normal sounds of the motor, the turning drum, and the...
You have done a good job of isolating the noise. Sounds like you will have to replace your drive motor. Very likely a mechanical problem in your motor, that is not going to fix itself. If you continue to run your dryer with the noise coming from your motor, you run the risk of the motor burning out electrically and causing a fire or a shock hazard. It is unlikely that this will happen, but it is possible and thereby not worth the risk of getting shocked or having a fire. The Whirlpool Duet Dryer is the best dryer built, so it is worth replacing the motor. Good luck, Appliance Specialists
Dec 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I have whirlpool duet dryer not turning, check belt its fine, turn drum its fine.
heatman101
Nov 04, 2010 | Whirlpool Dryers
We have a electric, front load electric Duet dryer that was working fine this morning and when my wife went to put a second load in.... it only beeps...nothing else looks wrong on the control...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 08, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool duet dryer does not run
You did not say if the motor is running, I have to assume that it is not.
You can try this...
Turn off the power to the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Then turn your power back on and push the start button.
Sometimes motors will get a dead zone in them and this will move it from the dead zone.
If that doesn't help then you need to check a little farther into why it is not working.
Could be a faulty motor, faulty start switch, broken belt, or maybe a faulty timer switch.
I hope this helps
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
666 people viewed this question
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Smitty
Level 1 Expert
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
