Question about Dryers
Kenmore 90 series gas dryer, NO HEAT!!!
Hello, i have a kenmore 90 series soft heat system (gas) dryer also has heavy duty / super capacity plus / quiet pak. for some reason it is taking me four 1 hours cycles to get my clothes dry. what could be the problem??? it spins it and it throws out very little heat. i know that the gas hook up from the wall for the gas is 3/8 but the gas line from the dryer is 1/2 could that be the problem??? it gas turnes on and stays on but it is not enough heat to get the clothes dry. im having a hard time with this... did not have this problem before. is there anything i can do to fix this... please let me know what i can do...
thank you for taking the time to help me out... your time is gratefully appericated...
smiles from a desperate woman!!!
  • 3 more comments
  • lidot Mar 26, 2008
    HI,
    I got the same with my kenmore kingsize 90 series gas dryer. I had no problem before but recently, it takes a lot of time [2 hours] to dry the clothes as there is no heat as evidenced with no warm air during operation. There is no problem in the exhaust line and lint screen is clean.
    Any advise to solve this problem?
    Thanks.
    Depressed Sofia
  • georgepet1 Apr 01, 2008
    kenmore gas dryer wont heat up , i have check it out with ohm metor ignitor shows power going thew it ,have change coils to burner still nothing , have checked radiant heat senor w/ohm metor shows it is ok , can an ignitor go bad even if it shows it is ok with an ohm metor?i dont see a glow from the ignitor when i turn it on
  • kevinstat Dec 03, 2008
    Our dryer stopped drying clothes also. The dryer turns ON and spins the drum at all the different settings (Timed Dry, Automatic Dry, @ various settings of HIgh Heat (Cotton), Medium,...) but we don't feel any heat (so something in the gas heating system must not be working. If you have any ideas let me know. The dryer is 10 years old, so unless I can fix it myself with minimal <$100 of new parts cost, it may not be worth it.
  • gusnodry Jan 12, 2009
    I have a Kenmore 90 Plus Gas Dryer, Model 78932. The dryer has no heat. The ignitor glows off and on in an attempt to ignite, the drum turns but no flame-heat. Last week ther was a flame on occation but it took 3-4 times as long. Now there is no heat at all. Vent is clear, Gas is on.
  • Anonymous Feb 24, 2009
    Same here we got a new dryer and is sucks. Not heat we thought it was a bad dryer so we took it back to the store only to get a second one that dose the same thing. We checked the vent...Clear...we checked the GAS its on and flowing....it puts out almost no heat. and when the gas is cycling it isn't on long enough to do any thing. Huge compliant here
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Posted on Aug 17, 2008
  • 156 Answers
Hi desperate woman yes first ck your vent from dryer to the out side home for good air flow if vent behind dryer kinked are vent going out is pluged be long dry times as far as the gas line goes it should be enough if the pressure ok at the gas meter further problem let me know
Posted on Mar 21, 2008
3 Suggested Answers
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
Posted on Mar 28, 2009
SOURCE: I have a Kenmore Elite
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Posted on Feb 13, 2011
My Kenmore Series 90 heavy duty gas dryer does not heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 19, 2011 | Kenmore Dryers
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Heavy duty super capacity plus Kenmore 80 series Electric drier the timer is running, but when I push the start button - nothing
the drum belt may be broken. you will have to check this, it goes around the drum and the pulley on the motor. you could also have a bad motor.
Oct 16, 2009 | Kenmore 73952 Gas Dryer
Mar 17, 2009 | Kenmore Dryers
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
6,005 people viewed this question
Top Dryers Experts
