Question about Kenmore Elite 45986 Front Load Washer
HE3t wont start
The door closes, the panel works, but when I press start, the door doesnt lock and nothing happens.
  • 1 more comment
  • Anonymous Mar 22, 2008
    same as above
  • Anonymous Apr 10, 2008
    There is a little black button that is depressed when the door is closed. I suppose the button closes the system so the washer cannot be stared if the door is ajar. This button had broken off, but we could not tell. $65 part, and all works well.
  • robert samples May 11, 2010
    i was telling you to spray wd 40 in the latch assembly not the start button some times that frees it then remove the top panel two screws in back and check for a loose wire if that doesnt work take an ohm meter and check the start button for continuity just becauses it pushes dont mean it works
There is a little black button that is depressed when the door is closed. I suppose this closes the system so the washer won't start if the door is ajar. The button was broken off, but we could not tell. $65 part and all's well
Posted on Apr 10, 2008
    Genius:
  • 1,554 Answers
Open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Posted on Mar 26, 2008
Troublecode b2100 on a 08 town car limo
371183c3-fa1a-49ec-833d-37326ebfd652.jpgTry this it should help you
Feb 11, 2014 | Cars & Trucks
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
When I close the door and push start it makes a buzzer sound and then nothing happens, sort of like it is not locking properly.
Hi - From what you have described it sounds like the door strike is not aligning with the door lock or the washer possibly has a defective door switch. I would suggest contacting a professional to move forward accurately and properly diagnose the unit.
Oct 14, 2012 | Frigidaire FTF2140E King-Size ENERGY STAR
How do I get my key remote to lock/unlock my toyota rav4 2002 model? I changed the battery because I thought that was the problem but it is still not working. The red light on the remote comes on but then...
You will need to try reprogramming the remote 1st, below is the complete procedure. If the reprogram doesn't restore function then you will need the dealer to test the keyless entry system, you may have a bad module or remote (only applies if both remotes don't work).
Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition(Do NOT Turn) Pull key out.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
3. Perform these steps within 40 seconds.
A. Close then open the drivers door.
B. Close then open the drivers door.
C. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
C. Close the drivers door
D. Insert the key into ignition and leave it in ignition.
E. Turn the ignition to ON (Do NOT Start) then back to OFF.
F. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Aug 24, 2011 | 2002 Toyota RAV4
It won't start. The panel lights up, but nothing
Either the door switch or timers is faulty. I would test with ohmmeter, voltmeter, or a multi-tester that has both.
Sep 16, 2009 | Frigidaire ATF6000ES Front Load Washer
Zanussi aquacycle 1000 start pause button
Try some WD40 on the door lock on machine (not on the door) & open and close a few times. Of course the mains plug should be off the wall socket.
Feb 28, 2009 | Zanussi IZ12 Front Load Washer
The alarm isnt working... car wont start, buttons wont work!
Just a possibility, but a discharged battery could be the culprit. Do the headlights come on brightly? Will the horn blow normally? A 'dead' battery will usually have enough power to illuminate LED warning lights, while not having enough current to operate the starter/door solenoids, etc. Have somebody test the battery voltage to be sure.
Mar 14, 2017 | Toyota Corolla Cars & Trucks
Kitchenaid dishwasher woudl not work MOD KUDPO1FLWH6
is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Dec 02, 2008 | Dishwashers
Washing machine wont start - close door message
Hi.
Most likely faulty door lock or door catch.
To access it, remove the clamp from drum front seal, and remove the seal from the front of the cabinet, undo the 2 screws that secure the door lock, and remove.
To test wether the lock is faulty or not, put a link wire across the (L) and (C)
connections on the lock, the m/c should now work, if it does not, then you have
a more serious problem.
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
164 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
