Re: Makes loud noise when running,like something is...
Make sure power is off .!!!!! either use small lfash lite to look around , or remove unit and turn sp side down and work it out ruber gasket is removable
Check the hook/shuttle to see if it is damaged
or check the race, the metal track that the shuttle/hook glides in there may be something jammed into the race
be very careful trying to remove a broken needle as you may further damage the race
The loud clicking noise is probably the carriage trying to move and something is keeping it from doing so. Check to see there are no foriegn objects obstructing the carriage head from moving across the paper.
If nothing is found, then likely a hardware error exists.
hope this helps!
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
dear sir the problem you have sounds like the solenoid that opens the drain actuater can be worn out open the bottom panel run tru a cycle observe when the solenoid open it may be that there is something causing the solenoid to buzz either worn out or a wire or something in the way causing not to close proprly thanks from gilles
sounds like the cutting wheels have something jammed inside them , can you take it bak and return it ? or open it up and see if anything looks bad inside ?
Very commonly a broken gear on the right side of the fuser. Replace the fuser and this will fix your issue. Let me know if you need a part number and pricing.
Mine makes a grinding noise when scanning or making copies. As long as everything is working, I just tolerate the noise in which the rest of the staff find amusing at first and then ignore it as I do.
