Question about Nokia 6111 Cellular Phone
Nokia 6111 I can't charge the phone though have managed to charge it recently inbetween intermittant bouts of being able to charge it. Therefore do you think that its the charger or do you think its the port as this is very wobbly? Many thanks in advance
    Brigadier General:
  • 7,752 Answers
If changing the charger and the problem is still there than have the charging port service or replaced.
Posted on Mar 21, 2008
  • 85 Answers
Change ur charger it deducts the problem weather in charer or port
SOURCE:
I hav nokia 6111 n its not charging can u plz help me wth diagram
You will find the schematic diagram at this site, check link
http://www.u2ugsm.com/mob_rep_detail_l.php?rep_id=1506
good luck
Aug 04, 2010 | Nokia 6111 Cellular Phone
I want a puk code for 6111 nokia
Service Provider will Provide the PUK Code for You..Get it that from them....
Jun 06, 2010 | Nokia 6111 Cellular Phone
MY NOKIA 6111 DISPLAY IS WHITE
white screen nokia 6111 problem
Dec 24, 2009 | Nokia 6111 Cellular Phone
Managing incoming calls
HI,
Nokia 6111 and Nokia 6300 are the ultimate phones and I like it very much.
SOLUTION:
1.Go to "menu". 2.Then select "settings" by scrolling down. 3.Inside "settings" menu, go to "call settings". 4.Inside call settings we can see various options to select that contains reject/show busy/divert.we can choose any one from them.
SOME TRICKS: Hiding your Mobile/ Cellphone Number
1.Go to: Menu > Tools > Settings > Call > Send My Caller ID >
"'Yes', 'No' or 'Set By Network'" to follow the default settings of your home network.
It works only with very few network who provide you facility of “Private Number”
Apr 17, 2009 | Nokia 1100
Nokia 6111 sim
my nokia 6111 moile cannot accept sim card
Aug 23, 2008 | Nokia 6111 Cellular Phone
Nokia 6111
first check your message center number if it is correct. or reformat your phone.
Jul 22, 2008 | Nokia 6111 Cellular Phone
Nokia 6111
if u have tried it yourself then it it could be possible that u may have damaged the flux cable(the connectivity cable between the main pcb and the display) or have disconnected it
Apr 05, 2008 | Nokia 6111 Cellular Phone
White screen nokia 6111
I had the same problem with my girlfriends 6111. I managed to fix the phone, but i did have to open it up myself and get a new ribbon cable to replace the damanged one. Basically one of the springs had been pushed the wrong way and this was acting like a scissor action on the ribbon cable for the screen. It cuts part of the cable so no image can be seen but power is still sent, thats why it only powers up white. Doing this yourself will void the warrenty but the warrenty on this phone had expired and i was being quoted £35-£40 to get it fixed. I managed to do it for a fraction of the cost!!!
Jan 12, 2008 | Nokia 6111 Cellular Phone
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Nokia 6111 screen not lighting up
shure.try to clean th motherbord & flexcabile with benzil cleaning liquid
Aug 14, 2007 | Nokia 6111 Cellular Phone
Nokia 6111 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
