Question about Belkin (F5D7132) 802.11b/g Wireless Access Point
BELKIN Universal Repeater - 2.4GHz-802.11g - (f5d7132) Setup problems
Hi, I am trying to set up my Belkin, Universal repeater, 2.4GHz-802.11g, Ive done the necesary and im not getting anywhere, maybe im missing something... anybody help?
  • Danger1016 Apr 23, 2008
    I am trying to use a belkin repeater and it only works some of the time. Most of the time I cannot connect to my wireless router and if i do it is really slow. Most of the time the red connect button just flashes. Sometime it works if i unplug the repeater for 10 seconds and plug it back in but that is only sometimes.
    Any help would be appreciated.
  • ant4979 Jun 05, 2008
    wireless g router isnt working tryed to re install and still no luck
My nephue has the same problem i told him to junk it and get a diffrent brand. He did and now he has no problem with the internet. Also I just tried to install it on my PC but all I get is a 10 seconds of internet then it does not connect after that. Thats why I was looking for any info on this problem.
Posted on May 06, 2008
My new belkin @TV can not be found by my kindle fire. Can you hook up an external WiFi device to it to get better range?
Chip - had a similar problem myself. What I did was setup a wireless repeater in my home. There are a variety of products out there that will fit your needs - a simple 'wireless repeater' search on Amazon or Google will provide you with various equipment to use (costs ranging from $50 to $200 - get the best you can afford that will over you the range extension you are looking for). Once the repeater is setup and connected to your primary router (via wireless), your Kindle should see the device.
One other point of note. I have used the Belkin @TV for a while now and tried it on a variety of different devices including the Kindle. I find that the Kindle performance wise isn't as good as an iPad or Laptop - just a heads up on that.
Sep 18, 2013 | Belkin Components Belkin G2V1000 TV...
Belkin (F5D8235-4) with Tp-Link TL-WR702N as a repeater
It needs to be configured as a repeater first.
http://www.tp-link.com.au/article/?id=397
Nov 14, 2012 | Computers & Internet
Manual for Belkin universal repater
Here is the manual for your repeater. Its a pdf document so it takes a few seconds for it to load.
Hope this helps.
http://cache-www.belkin.com/support/dl/p74992_f5d7132_man_uk.pdf
Nov 08, 2009 | Belkin F5D7132 Repeater
Is Belkkin F5D7132 compatable with X box
THIS MAY NOT BE HELPFUL BUT I DONT KNOW TRY IT TO SEE WILL IT WORK
Sep 23, 2009 | Belkin F5D7132 Repeater
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin f5d7132
For best results, you should connect it directly to the other router with an ethernet cable.
Jul 21, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Repeater
The repeater must be the same brand as the signal it is repeating. Different routers / access points work in slightly different ways and the current generation of wireless repeaters aren't smart enough to work with other brands.
It's kind of like trying to put an engine from a Nissan Altima into a Honda Accord... both make the car move but they aren't the same inside.
Oct 31, 2007 | 3Com OfficeConnect (3CRWE454G75)...
Belkin (F5D7132) 802.11b/g Wireless Access Point Logo
3,477 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
