GE JGRP17 Gas Single Oven Logo
Posted on Mar 21, 2008
Starter My starter for my gas stove top will not stop making a spark. The clicking is driving me crazy. Everthing works fine. It will light and the burners work great it just won't stop sparking even in the off mode
  • bon Bou May 13, 2008
    Was cleaning my GE profile gas cook top when suddenly the spark starter started and now does not stop even when all the dials are off. The cooktop is only 3 year old and has not been used very often. Looks like GE manufacturing its cook top in China? No step already taken to solve the problem
Robert Weir
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Mar 22, 2008
Robert Weir
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
19881
Points
37
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Gas stove starter is not clicking or trying to light. Were is the starter located.
im the boss1,
If you can get me the model number to your oven I will send you a diagram of it.
Other than that the igniter is inside the oven towards bottom back.
Appliance Parts
Gas stove with electric starters for the burners. One keep clicking after it lights. How do you stop the clicking?
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
6helpful
2answers
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 • Ovens
I have a whirlpool gas stove, the bake or broil will not light.
Check to see if the electric ignitors are connected at the ignition module, located under the top surface panel. It is possible that the wire(s) that go to the oven ignitors has burned off or become disconnected from the main spark module,
It is also possible that the electrodes have failed and need to be replaced. These are the two (2) devices that produce the spark (and make the clicking sound) inside the oven compartment.
If those are OK, then check the thermostat, as it could be faulty and preventing the oven from functioning.
If you can smell gas when attempting to turn the oven (bake or broil) then the valves are good, if you don't smell any gas, the gas supply valves (one for each bake and broil tubes) need to be checked.
You might also try lighting the oven manually with a long match or grill lighter to rule out faulty gas supply valves or a faulty thermostat, which if you can manually light the oven, it would prove that the ignitors must have failed.
Here's the exploded line drawings for your stove along with the parts list, just click on each section to see the parts. You can order replacement parts from them as well.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=gw395lepb02&pop=flush
Hope you find this Very Helpful and best regards!
Aug 28, 2009 • Ovens
Whirlpool counter top gas stove electronic ignitor sparks all the time,had to unplug to make it stop
The spark ignitor has failed. Have it replaced and that should stop all the extra clicking. Hope this helps. Good luck.
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 • Ovens
4helpful
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Model fgf337asa
Turn your gas knob to ON position. Let me know if it does not work,
14helpful
2answers
Gas Stove - Electric Starter
Just happened to me. I unplugged the electric starter, wiped up the water, took off burners, etc., and placed a fan over the stove. After about 3 hours, I plugged in starter and the clicking is no longer.
Sep 23, 2007 • Ovens
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
