Question about Lightning Audio FF150.2 Car Audio Amplifier
Pb2600 car amp
My pyramid pb2600 doesn't have really 2600 watts?
  • 27 Answers
It might, at say...6000% distortion. For a true amp power rating look for the RMS per channel specs. This is a much more realistic rating of what the amp can actually put out continuously...
Posted on Mar 21, 2008
How do i set the time on a pyramid 2600
Time on an amplifier? Thats a new one on me.
Nov 14, 2014 | Car Audio & Video
Is my Pyramid 300 watt mosfet pb 772 compatible with a 10" kicker comp sub?
If the output impedance of your Pyramid amp is approximately the same as the input impedance of your Kicker, it should work.
May 12, 2014 | Kicker Car Audio & Video
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have a pyramid amp and i don't know what watt it is and it doesn't say. the model no. is PB-700A. it's an older amp thank you
  • 4-Channel
  • 350W X 2 Max @ 4ohm
  • 700W X 1 Bridged @ 4ohm
  • Dim: 2.4"H X 10.7"W X 6.9"L
  • Mosfet Pwm Power Supply
Jun 07, 2011 | Pyramid Car Audio & Video
Need advice on setting up amp with my two speakers.
This is hard to explain and what needs to be done is wire in parallel both subwoofers. This website will help just put in the amount of speakers and amount of ohms each and it gives you diagram.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=81#results
Mar 24, 2010 | Pyramid ZPA150 Car Amp
Amp for 12" Alpine Type R DVC 4ohm
i actually have 2 12" type s's and i did the same thing just wanted a cheap amp... i went on ebay and bought a pyramid 1600 super blue series amp..... its 1600 watts and ive also hooked it up to type r's and it POUNDS!!! ill copy and paste the website where i got mine from on ebay... if you tune it right it'll make it so you cant breathe inside your car......http://cgi.ebay.com/NEW-1600-WATT-PYRAMID-PB559X-Car-Audio-Amp-Amplifier_W0QQitemZ350169009069QQcmdZViewItemQQptZCar_Amplifiers?hash=item5187b30bad
Nov 11, 2009 | Alpine Car Audio & Video
1600 watt pyramid royal blue 2 channel amp need diagram of amp itself
if i keeps blowing fuses then it means the amp is bad
May 12, 2009 | Car Audio & Video
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
When i turn my radio up all the way my speakers cut out and then come back on
Yes it is probably too powerful for those speakers. Or the speakers could be defective.
Jan 13, 2007 | Swiss Audio SW12 Car Subwoofer
Lightning Audio FF150.2 Car Audio Amplifier Logo
70 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Richard Lukszys
Richard Lukszys
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
