Re: Our copier IR 5000 sudden die. any suggestion ?
Die as in no power? check breaker on back of machine it is resetable. Switch off then on, then switch main power switch on right rear on again to check.
no you can not, the toner in a image press is a dual component toner. in the 5000 and 7105 are a mono component toner please dont and if you did please tell the tech because it will drive him crazy trying to figure it out unless he is a veteran in the copier business.
Hello, I would recomend You the two second hend refurbished iR 3300 Copier ( B&W ) or Ricoh AF 1045/2045 and color clc 3200 for color, for the beginning and if you want later take stronger 50ppm i.e. IR advance 6055 for B&W and IR ADVANCE C2030L.
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
sst itu Service Support Tool kl sm apa ya? kalo mau sst nih linkya http://techchatter.servehttp.com/yabbse/index.php?topic=356.0 n nih frmware ir 5000-6000 http://rs147.rapidshare.com/files/197499533/__304_R5000-6000.rar
That error means that you have a problem with the drum motor. Check the it's connectors. Or maybe something keeping the motor from running, like an uptwisted blade with drum.
