Question about Garmin Quest GPS Receiver
Garmin Quest No matter how many times i load map to my quest unit it still tells me "no map" can be displayed.It worked fine for over two yrs .Now all I get is a blank screen with the words "no map" in bottom left of screen.It still tracks satellite and picks up on points of Interest but no roads Any suggestions
  • terrybickers Jun 20, 2008
    My Quest has 245mb of memory for maps, but when I download maps I can only get about 25mb of maps to load. If I try to download more than that, I don't get any maps loaded at all, I can only then use the preloaded base maps.
Hello, I currently own a Garmin quest myself, and some time ago I had some strange problems myself, I am a electronics technician, and I do have a work around for you. I will explain the problems and a cure for you to try, none of the work arounds depend on any parts to be removed.
1. NO RECEIVING SATELLITE TELEMETRY. I beleieve this could be due to a number of reasons, but more so at sometime corrupted telemetry was the problem to fix this,
a turn GPS on when booted (initialised)
b. depress menu
select settings
select Time Setup
when in Time Setup depress MENU
Select SET DATE
Depress OK button
Depress OK button again on the numberic keypad that appears on the screen (DONE)
what this seems to do is resets the internal date/time clock and the unit starts to work again.
the Second workaround is this but takes hours to perform.
Simply turn the Guest on and allow the battery to fully discharge, usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Posted on Jun 08, 2008
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Quest unit not accepting map info
u need a firmware update i think
Mar 21, 2008 | Garmin Quest GPS Receiver
Garmin Quest: Not able to upload detail maps
hi bud, just had the same problem. hard reset i.e turn off unit, hold down ok, page and then the power button at the same time. it should then ask you if you want to delete all data. select yes and then you should be able to upload your maps again, this worked for me good luck
Feb 18, 2009 | Garmin Quest GPS Receiver
Screen froze up
"If your Quest locks up....on rare occasions, your Quest may freeze or lock up. In this case, reset the Quest by pressing the unit's Power key and the IN key at the same time. This will turn off your Quest. The unit will operate normally when you turn it on again."
Aug 02, 2008 | Garmin Quest GPS Receiver
Garmin Quest
a turn GPS on
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil email pjb3103@bigpond.com
May 24, 2008 | Garmin Quest GPS Receiver
Garmin Quest is out of whack
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
phil
Apr 04, 2008 | Garmin Quest GPS Receiver
Rong turns
Hello, I also own a Garmin Quest GPS and I live in Australia, Invariably my quest sends me in the wrong directions, and also in the middle of a highway get a message do a U TURN. I only believe this error resides in the MAPSOURCE Software. and until GARMIN decides to fix the problem there is NO solution for the USER to FIX. I also do NOT believe any more the specification that garnin states with the quest GPS, I believe it can ONLY be bad Telemetry downloaded from the satellites or you have TOO MANY waypoints stored in your GPS. The Solutions I am about to give you are my way of fixing the GPS until the problem reoccures. I suggest you do OPTION 2.
b. depress menu
select settings
select Time Setup
Select SET DATE
Depress OK button
OPTION 2 Before you do this DO YOU KNOW HOW to RELOAD your MAPSOURCE MAPS.
Simply turn the Guest on and allow the battery to fully discharge, this is also a good practice to cycle the battery. usually this works to TOTALLY flush the Memory again, but on my unit I have to setup all the maps again, this is easy to perform, but just takes time. I hope this helps you.
phil
Mar 23, 2008 | Garmin Quest GPS Receiver
Quest .No maps coming up on screen
I already suscribed,and ,no , its not fixed.The person I was assigned had less of a clue than I did.What do I actually get for my $19.99 that I sent on paypal????
Mar 16, 2008 | Garmin Quest GPS Receiver
Can't get maps to unlock
Call Garmin support @ 1-800-800-1020
Feb 09, 2008 | Garmin Quest GPS Receiver
Garmin Quest unlocking maps
i BOUGHT A QUEST ON E-BAY, WHEN I TURN IT ON AT THE BOTTOM OF THE SCREEN, " CAN NOT UNLOCK MAPS" HOW CAN i UNLOCK THIS UNIT SO I CAN PROGRAM IN CITIES AND STATES.......
Feb 06, 2008 | Garmin Quest GPS Receiver
Garmin Quest GPS Receiver Logo
124 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
