Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
MDB5600AWQ Will not drain
Serial #25399766ET
My unit will not drain all of the water after the cycle has finished. I do not see any clogs but it leaves standing water in the bottom of the unit.
Can you help?
Thanks
Bill Pearson
bgdddy1965@yahoo.com
  • Anonymous Apr 15, 2009
    when the dishwater is finished there is some water at the bottom of the unit
    President:
  • 1,314 Answers
Yep first disconnect the drain hose from the sink drain then get a mop bucket shut the door and start the dishwasher the fist thing a dishwasher does when you start it is drain before it fills hold the bucket under the sink and loop the hose up and like its connected and see if it drains if it does then check the sink connection for an obstruction if not pull the bottom kickplate you will find a tech sheet there that will be help full also look to the left hand side and you will see a small drain pump make sure the wires are hooked up you should hear the pump running when you first start the dishwasher before it fills after the pump stops running open the door and turn it off if the pump is running and no or very little water is coming out of the hose then you will have to remove the pump and check to see if something is jamming the impeller reply to me if you need to and we will take it from there ok
Posted on Mar 23, 2008
Not finishing cycle
Is it draining out the water?? Dishwashers fill, spray, and drain more than several times during a cycle. After starting a cycle, let the unit fill, start spraying, and then cancel the cycle--listen for the drain pump activating and pumping out the water. If water is not being drained properly(within a certain time limit), the unit will error code out and stop. Also, make sure the filter is clear--if it gets clogged with "muck", enough water won't be sprayed onto the dishes properly, the pump will require too much energy to try to pump water, the control will sense this and shut down the unit to protect it.
Jul 25, 2015 | KitchenAid KDHE704DSS 24 6-Cycle/7-Option...
My asko 3122 dishwasher wont drain
It is likely that there is some minor clogging in the diswasher drain filter.Clean as per the user instructions available with the dishwasher. Also likely the kitchen drain could be clogging. Buy a dishwasher cleaning kit from supermarket. Finish make a good product. Use it to clean the dishwasher as per instructions on the kit.
Nov 27, 2012 | Asko Dishwashers
Asko 3122 wont drain
I think I have replied to this already. Filters or drains might be clogging up. Clean dishwasher using Finish dishwasher cleaning kit.
Nov 27, 2012 | Asko D3122XLSS Stainless Steel Dishwasher
Water was not pumped away, cleaned everything, but power is off and cannot switch the dishwasser on again
Hello when you stated water is not pumped away and that you cleaned everything and now the power is off did you check the float switch in the unit? If the water was not pumped out of the dishwasher then either you have a clog in the drain line either where it goes into your disposal or sink area or in the drain line, or the pumps impellar is not spining or something is cloged in the pump stopping the impellar from moveing. I would first look at the float switch in the unit this is a small switch that tells the unit to either add water and start your cycle or drain water and finish the cycle. I will await your reply as to you finds before diagnosing further. Thank you
Rick
Nov 19, 2011 | Miele G 1470 SCVi Built-in Dishwasher
When dishwasher finished power wont go off and cycle light flashing
Seems that the end cycle report had not reached the main controller unit and so it seems to sense and error.
Please check and see if the drain pump is clogged, remove the unit and see if there is dirt clogging that does not allow the water to drain off.
Also check the inlet valve and the inline filter for a good flow as the duration of the program cycle must end in the specified time or it might result in an error.
Sep 08, 2011 | Bosch Dishwashers
Some Water is retained in the basin after finishing the wash cycle. Kitchen Aid: Model SUDS 220T0 Serial T-X 1293892
This may be as simple as the location of your drain hose, where it attaches to the main drain.
On a new installation, If the connection is too high, gravity itself will keep some back. On older units, as the pump isn't quite what it used to be, you get some left-overs
If neither is the case, check the drain hose under the unit, as well as any area of hose where a 'dip' is present, for clogging. Just like hair in a sink trap.
Hope this helps.
Jan 31, 2010 | Dishwashers
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
GE GSD4920Z dishwasher. Problem is that it does not drain completely at the end of the cycle--about an inch of water remains. After checking for clogs, etc, we followed a troubleshooting procedure which...
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | GE 24 in. GSD4920Z Built-in Dishwasher
My kenmore ultra wash plus is not draining
Hi
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
307 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
