Question about Symantec Procomm Plus 4.8 for PC
Procomm Plus When I click to open Procomm receive the following error message "error reading pw4.prm file"
2 Suggested Answers
  • 84 Answers
SOURCE: I installed Norton 360 and
Well may be you must chek for norton updates or you have bought the older version....
Look for updates in homepage at norton.com
Posted on Dec 10, 2008
Disk fragment
You need to run chkdsk...
How to run Chkdsk
Notes
Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt
Click Start, and then click Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)
Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer
Double-click My Computer, and then right-click the hard disk that you want to check.
Click Properties, and then click Tools.
Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
To run Chkdsk in read-only mode, click Start.
To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?
Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Exit code Description
0 No errors were found.
1 Errors were found and fixed.
2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified.
3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
Aug 19, 2012 | Computers & Internet
Bad sector issue
How to run Chkdsk
Notes
Jun 30, 2012 | Western Digital Caviar Computers &...
Windows can't recognize
You need to run chkdsk......
How to run Chkdsk
Notes
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
Oct 14, 2010 | Acer Aspire 5315 Notebook
Lost right click capabilites.
You may experience any of the following symptoms:
  • When you right-click a file, Windows Explorer may quit unexpectedly, or you may receive an "Access Violation" error message, or you may receive the following error message: Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. When you view the details of the error, you find an error signature similar to the following: AppName AppVer ModName ModVer Offset
    Explorer.exe 6.0.2800.1221 Ntdll.dll 5.1.2600.1217 00054084
  • After you install Windows 2000 Service Pack4 (SP4) or the 823980 security patch (MS03-026) documented in MicrosoftKnowledge Base article 823980, you may not be able to open .max or .drffiles in the following products:
    • Discreet 3DS Max versions 2.x, 3.x, 4.x or 5.x
    • Autodesk Architectural Desktop 2004
    • Autodesk Building Systems 2004
    • Autodesk VIZ 4
    • Autodesk 3D Studio VIZ R3 or R3
  • YOU CAN RESOLVE THE PROBLEM BY VISITING HERE
Mar 25, 2009 | Microsoft Windows XP Home Edition
My procomm plus issue
Procomm Plus and norton 360 are compitable to each other but r not not compitable to work on your operating system .u will just need to format your pc and clean the Procomm Plus files from it and then also delete the norton 360 from your operating system.and then u will be able to reinstall the Procomm Plus after formatting the pc.then instead of norton 360 install any other antivirus software like symantec or avg
Dec 10, 2008 | Computers & Internet
Error message for TI-84 Plus
Try and resolve this issue by re-installing the calculator's operating system using the TI OS Downloader. To do this, please follow the steps listed below. Be sure you have fresh batteries in your calculator.
1. Download the OS 2.43 file to your computer (preferably the desktop).
2. Open the TI OS Downloader by going to Start>>Programs>>TI Tools>>TI Connect>>TI OS Downloader. If you do not see TI OS Downloader, you may need to install the latest version of TI Connect. You can download a free copy from:
www.education.ti.com/downloadticonnect
3. From the main screen, select your calculator and cable type. Click "Next" to continue.
4. From this screen, locate the OS 2.43 file by clicking on the yellow browse folder and navigating to the location where you downloaded it. Double-click the OS 2.43 file to select it.
5. Remove one triple A battery from your TI-84 Plus. With the battery removed, press and hold the [DEL] key while you re-insert the battery.
6. You should see a "Waiting..." message on the screen of your calculator. If so, disconnect the USB cable from your computer, re-connect it and then click "Start Download". This should begin the OS transfer process.
Aug 19, 2008 | Texas Instruments TI-84 Plus Calculator
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Y-Modem file transfer aborts
Otie, Is this the only unit having trouble? Have you checked your firewall settings? Not knowing the error messege I will just throw my 2 cents in... Have there been any updates to the XP Pro? Has there been any ProComm updates that may have affected the machine. You may need to reset and reconfigure the modem. There could even be some kind of interference at the Telco Office. Just some thoughts, Tim
Feb 02, 2007 | Hawking (UC232S) Serial Adapter
Symantec Procomm Plus 4.8 for PC Logo
179 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
