Question about iLO 2600 Television
Wont start ilo lcd tv 27" Model: lct27ha36. Only the red light come on in the front panel.
  • 5 more comments
  • edh63 Mar 30, 2008
    Model LCT27HA36 - won't come on - only red light on in front but no picture on screen. Have tried to power up from several different outlets. TV is less than a year old. Went to 2 different Wal-Mart stores but they no longer even carry the Ilo televisions. What do we do now?
  • Anonymous Apr 03, 2008
    Same problem...anything guys? [email protected]
  • jcal Apr 05, 2008
    TV won't come on. Onlty the red lights shows up.
  • ocoeedreamer Apr 19, 2008
    OMG, I had to run to the store, of course I turned my iLo tv off. When I returned, It would not turn on. Only the red light.... nothing else. This is the first problem I've had with my tv. I have had my tv for a little over a year now. I hope there is a simply solution to this.... I can't afford another tv at this time... hard enough being a single parent and paying all the bills... enough of that. Please any advise would be welcome. Thanks :)
  • janipierce Jul 12, 2008
    Me too...I brought mine a year to the date and would like to avoid buying another flat screen if there's a simple fix to this issue. Could it possibly be the power supply board needs to be replaced?
  • 420taz Feb 13, 2009
    My TV wouldnt turn back on after being turned off. You can hear the power in it but the red light refuses to go green. I should have done more research before buying some off brand. I liked the picture quility but after a year of owning it almost to the day...this happened. They should recall them all since it seems everyone is having the same problem with this TV.
  • shutterbug20 Mar 11, 2009
    My sister has the same problem, only the red light comes on. Out of the blue turned off an know wont turn on. Any response to any one? I am trying to contact the company and that has been a chore and still cant locate it. Will up date when I find it.
Hi all. I came across this forum after "Googling" this particular model ilo TV. (LCT27HA36) Like a lot of you, mine would not turn on. It was just like lambon48's TV. Since I could not find an answer online, I took it upon myself to solve the problem. I am a retired radio engineer, and have experience in repairing a vast assortment of electronic equipment. The problem with my TV was isolated to the power supply board. I found several capacitors to have bulged. That is, the tops were swelled outward. This usually is a sure sign the capacitor is bad. The ones that were bad were all of the 1000 uf capacitors and one 470 uf capacitor. Now these caps were rated at 16 volts and 25 volts. When I replaced them, I used 35 volt rated capacitors. These caps can be bought at Radio Shack for about $1.60 each. It cost me $10.50 to fix my TV. I recommend you having only basic knowledge of soldering to do this. Just take your time and notate how the caps are installed before you remove them.. Please make sure you install the caps properly. That you put the positive and negative legs of the capacitor in the proper holes. If your board is like mine, the positive side is marked on the circuit board. If you are hesitant on soldering, I bet you know someone who can do this for you. Good luck.
Posted on Sep 11, 2008
Thanks, CCScan! Your solution was perfect! I had the same problem as everyone else here. I have a friend who is great with electronics, and he agreed to help me out. We opened the TV, and sure enough, three of the capacitors were bulging. We drove to Radio Shack and picked up three 35 volt replacements for under $5. My friend already had a soldering iron and solder, so there was no additional expense for that. We went back to my place, and the whole operation took about 10 minutes. After that, we put the TV back together, and it worked like a charm! You saved me plenty of money! Thanks, again.
Posted on Jan 18, 2009
I also had the bulging caps on the power supply, replace the 1000uf 16v with 1000uf 35V. Under the metal sheild on the display I also found a 220 uf 16v cap that exploxed. Its located near where all the wires come in through the metal sheild. A wire with a ferorite <sp> ring sits almost on top of this cap. I replaced all that and it worked fine. Thanks CCScan
Posted on Nov 15, 2008
Ccscan's solution is the absolute best answer for this problem if your tv is no longer under warranty. It took about twenty minutes to take the tv apart, replace the capicators, and put the tv back together. The best part is at the most it will cost you about fourteen dollars, if you have to buy a soldering iron like I did, as opposed to the hundreds of dollars repair shops will charge you.
Thank you ccscan.
Posted on Oct 30, 2008
I had mine unplugged and it did not reset pice of junk no tv shops will take it because of unknown brand
Posted on Sep 24, 2008
I had a similar problem with my ilo hdtv. If you unplug the tv and leave it unplugged long enough for the capacitors to discharge that should reset the tv. I had mine unplugged for about 2 weeks!!! Then i tried it again and i have not had the problem soo far. Hope this helps.
Posted on Apr 11, 2008
SOURCE:
TV won't power up
Likely a failed fluorescent backlight or the inverter that supplies the high voltage to it. I'd like to suggest a potential source for parts or service but the earlier authorized service company was Initial Technology and their webiste is no more so the company is probably defunct. Ilo was sold only by Wal-Mart and our 32HD failed after 6 weeks and when returned after several weeks from repair, had the LCD panel damaged which didn't show up until we tried using it full screen and saw the flaw.
You may have some luck here:
Possible Ilo parts source
Otherwise, I'm afraid your friend is just another victim of a Wal-Mart junk supplier.
Aug 18, 2009 | iLO 3200 32 in. LCD Television
Model number LCT27HA36..will not turn on????
This TV is using a power supply MLT168A that has defective capacitors. Replacing the capacitors might fix it, but in some cases the failure is more then capacitors.
Write to [email protected] if you required further assistance.
Aug 17, 2009 | iLO Televison & Video
ILO 27" LCD don't start up.
check batteries in remote, does it click back into stand by when u press power button?
Dec 11, 2008 | iLO 3200 32 in. LCD Television
27 in.lcd tv ilo power wont come on using remote, or set button?
lcd tv 27inch wide screen, mo. 1lo lct27ha36, no power, power lite stays red, if i hold power on lite just flickers. this type set has no on off pulling the wall plug is the only way to kill the power to the set.
Oct 01, 2008 | Televison & Video
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Ilo lct27ha36
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Apr 01, 2008 | Televison & Video
ILO LCT27HA36 No Manual
This is a very low end low quality made TV set. I would suggest you take it back and see if you can exchange it.
From my experience, I would suggest getting a good quality brand name TV set. Most of the Sony LCD TV sets have earphone jacks, external outputs, and come with a full set of instructions. They are also strongly supported for service during the warranty period.
Jerry G.
Oct 15, 2007 | iLO LCT32HA36 Television
Ilo lcd tv lct27ha36
I having the same problem. Called the company $80 for a new remote. I only paid $300 for the TV. The company said they have not given out the code for the television. What a CROC! Like the TV, but probably won't buy another.
Sep 23, 2007 | iLO V27DMBX Television
Televison & Video Logo
269 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
