NO PICTURE BUT HAS SOUND
I have a JVC TV with IC BT1226EN so i replaced the IC but the new IC didnt display anything yet the old one displays menu but no picture so could you help me with the Ic labling of TB1226EN to see if i can follow the video signal or advise me on what to do its for a client and i have tried but all in vain.
  • 62 Answers
Hiii.....
Ekisa...I see the TB1226xx likes chip/ic for Video Chroma and syc signal processor NTSC/PAL?SECAM color TV ( by Toshiba )....I can give you the Datasheet by e-mail...
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Posted on Mar 22, 2008
I have sound but no picture
If it's LED or LCD then it's backlights-- just shine flashlight on screen at an angle and see if you can see any movement or bring up menu display and with a flashlight you should be able to see it---as stated above---
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing inverter will solve the problem---ou cannot see anything at all then it's T-Con board--
Feb 14, 2016 | JVC LT42X579 42-Inch 1080p LCD HDTV
Picture bowed
This is called vertical pincushion IMHO.
With a bit of luck you should be able to adjust this from the service menu.
Access the service mode: set SLEEP TIMER to 0 MIN.
While this is still displayed, simultaneously push DISPLAY and
VIDEO STATUS.
Oct 19, 2007 | JVC AV-48WP30 48" Rear Projection...
Sound ok but no picture
see the b. diagram and test the power supply ;transistor, fuse, filter, switch, c.breaker rectifier,IC regulator voltage.
measure the horizontal output =125vdc
all other circuit:12vdc
color:12vdc
Oct 17, 2012 | JVC Televison & Video
No picture total black screen
Total black screen is usually as a result of 2 things. The first being either the contrast or brightness being reduced to the lowest point. this makes the screen display to look like it is not showing anything at all.
The other being that the picture ic of the unit is blown. In this case you need to refer the unit to an expert to trace the particular ic order a replacement for it and replace it.
Hope this solution has been helpful?
Dec 01, 2010 | JVC AV-32D302 TV
Tv has sound but no picture
the problem is from your picture IC. The picture IC of your TV is faulty and need to be changed/replaced for your TV picture to display again.
Good luck.
Mar 11, 2010 | Televison & Video
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
JVC Vertical Problem
You need to adjust the vertical height in the Service menu.Press the SLEEP TIMER key and set the SLEEP TIMER for 「0 MIN」. Then press the DISPLAY key and VIDEO STATUS key of the remote control unit at the same time to enter the Service menu.In SERVICE MENU, press the FUNCTION ▼/▲ key to select any of the SUB MENU items. (The letters of the selected items are displayed in yellow.)You want #2 DEF - go to sub-menu and look for the height adj. FUNCTION / key Setting (adjust) the SETTING VALUE of the SETTING ITEM. When the key is released the SETTING VALUE will be stored (memorized). EXIT key Returns to the previous screen.
Aug 22, 2007 | JVC AV-27320 27" TV
JVC i art 32" flat screen
Ur video ic inverter board is dead.
U need a new one.
May 13, 2007 | JVC AV-27530 27" TV
Got picture but no display...
Yes it could be the microprocessor IC or the display IC. Im not sure how the display system works as I do not have a schematic for the set. now what I have seen in the past, is that when the flyback blew out it sent a spike pulse way bigger then it should have been and blew out the display sync circuit, and that is built into the microprocessor. Also I have seen in the past, when a main componet such as a flyback transformer is replaced, there are small surface mounted componets near and around the flyback that gets unsoldered. These are ussually small surface mounted type resistors or capacitors that send a pulse to sync up the display output with the horizontal and vertical sweep, or the display would not know where to be and would run so fast along the screen that you would not see it. Check out the horizontal pulses to the micro, or like I said the micro is bad. Good Luck
Oct 09, 2006 | LG 30FZ1DC 30" TV
Televison & Video Logo
164 people viewed this question
Top Televison & Video Experts
Electro Med Services...
