We have a Xerox Phaser 7700, can we reset the chip on the print cartridge, if so, details of chip resetter, etc. Many thanks
Hi- did you find a solution. i would like to resent my imaging unit. I know it probably can go another 2500 copies.
Jeff
Posted on Apr 18, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
Xerox 7700. Paper is jamming at lower tray and bypass tray. Will print one page fine but multiple pages it stars jamming
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Nov 18, 2010 | Xerox Phaser 7700 Laser Printer
I want hp 8500 chip resetter so plz help me to find out.
So far, for some reason, there have been no resetters for this particular printer. Aftermarket inks require you to either replace the chip with the chip from a used cartridge, and this will work, for a while, but eventually, it will stop printing, and not much you can do, but buy new cartridges.
PLEASE note:
Eventually, is a loose way of saying the following:
Either the chip will "time-out", or report full and complete "depletion" after which nothing will get it printing again.
I've dealt this this issue personally and can attest to this fact.
Mar 10, 2010 | Xerox Phaser 8500/DN Printer
Xerox - replacement toner cartridge problem
Not that I know of. Did you receive a chip with the toner? If not that chip would need replaced to reset the counter;
Feb 20, 2010 | Xerox Phaser 6125 Laser Printer
Phaser 7700 prints slow
You have to clear the memory.. once you clear out the memory then it will work properly again. What this does it loads up the factory settings.
1. From the Main Menu, highlight Support and press OK.
2. Highlight Service Tools Menu and press OK.
3. Reset NVRAM is displayed, press OK.
4. Highlight Reset NVRAM and Reset Printer NOW and press OK to reset all
the settings to default.
Sep 28, 2009 | Xerox Phaser 7750DN Laser Printer
Hello, how to reset toner cartridge for xerox phaser 3100mfp. Regards, Teodoru
Through Module we can resetted Xerox 3100 permanently.
www.nakshatraworld.com
Aug 06, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox phaser 7700 paper feed transparency errors
There is a Transparency sensor (called the OHP) which is part of the Registration Transport 116-1164-00
Clean it first. Or replace the whole assembly
Whit
Item, Inc.
Mar 24, 2009 | Xerox Phaser 7700DN Laser Printer
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
