Question about Apple iPod MP3 Player
I pod only turns on then shuts down and comp doesnt reconize it
Well,
2 weeks ago i unplugged my i pod like i always do and it just kept turning on then shutting down and doing the same thing over, then i was going to plug it into my computer, but my computer didnt reconize it all that was on the screen was low battery please wait, but it never did anything for me.
so it would be nice for some help
thnx [ = I get the apple support ipod screen with a folder on it.
Or I get the unhappy face image
    Genius:
  • 3,422 Answers
it might just be a glitch. try holding down the middle and the menu button for a few seconds.This usually works if it doesn't then please follow some trouble shooting steps listed below:
Make sure the Hold switch is off
  1. Check to see if the Hold switch is on. It's located on the top of iPod. When it's in the on position, you'll see an orange patch.
  2. To turn the hold switch off, slide it until you no longer see the orange patch.
  3. Press any button to turn on iPod.
Make sure the battery is charged iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and Fifth Generation iPod can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let iPod's battery drain In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
  1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
  2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software If iPod turns on after you reset it, download the latest version of the iPod Software Updater, and update iPod.
Additional information If you have tried the solutions above and iPod still won't turn on, check the following:
  • Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
  • Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
  • Try connecting iPod to the built-in port of a different computer to see if that works.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 21, 2008
  • 871 Answers
You need to reformat your ipod and upgrade the firmware after reformatting. to do this you need itunes.
  • earl norman llanera
    earl norman llanera Mar 21, 2008
    if it still wont solve the problem, kindly try replacing the battery.
    Sergeant:
  • 406 Answers
Your Ipod battery requires replacement
  • Rafique Mannasaheb Mar 21, 2008
    I am online i am waiting for ur feedback
SOURCE:
A few days ago my mouse( CordlessClick/Plus) started to not work unless it is total near to ( few centimeters from )the loading/transmitter-station --- why?
try unpluging the transmiter shut off computer then turn comp back on wait til its up all the way then plug the transmitter in then it should reload the comp should reconized new device and update it in your system see if that makes it work better
Nov 12, 2012 | Logitech Cordless Click! Plus Mouse
About 2-3 weeks ago mouse went couldn't use, then the key board went out about a week ago. Shut down the computer, turn comp. off from back then upluged. after check to make sure everything was still...
Impossible to diagnose remotely. You need to try things like switching the computer off at the mains for a few minutes. If I had the computer I would try a different PSU.
Oct 22, 2017 | Biostar M7VIZ Motherboard
I have a hp pavilion ze5170 laptop and it is shutting itself off for no apparent reason. anyone know what could be causing this? it doesnt appear to be software related. its not crashing just turning off.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Aug 28, 2010 | HP Pavilion ze5170 Notebook
When i first got it... it worked with no prob. all the sudden it doesnt work. i try to unplug the usb and restarting comp... still wont reconize the wireless
you know it always happens on a wireless mouse so thats why im not recommending to use wireless intead the best is use an ordinary optical mouse.
Oct 05, 2009 | Targus Wireless Optical Notebook Mouse...
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
I pod touch not turning on or charging
your ipod touch is probably toast if i were you i would bring it in if you have a warranty
Dec 31, 2008 | Apple iPod touch
Deleted files
yeah unless you still have the files on your computer. but if you dont just download them all over again.:( I know it sucks but i think it will work
Feb 05, 2008 | iLO (2 GB) MP3 Player
Your battery is dead!!! Try to recharge with USB adapter!!! If that doesn't work you need to change battery. Give me some spec. about your MP3!
Jan 25, 2008 | Apple iPod nano 3rd Generation
Sound like you need a battery replacement on that iPod. The only other possibility is that your motherboard is starting to corrupt and will need to be replaced. If you want some repair options or want to recycle that iPod, let me know.
Rick
EverGreen Electronics
Jan 21, 2008 | Apple iPod MP3 Player
Apple iPod MP3 Player Logo
88 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
