Question about HP PSC 2355 All-In-One InkJet Printer
Problems printing printer will not copy or print but takes in paper - it shoots it straight out but stops half way - we then have to press OK for the paper to be ejected. The size of the paper makes no difference and it continues to take in pages even after the print has been cancelled - help
    Novelist:
  • 188 Answers
Hi Annoyed,
Please click on the web link given below and download the Printing Diagnostic utility to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-56143-2&cc=us&lc=en&dlc=en&product=422000
This will fix the issue.
Check wether you have full ink levels in the cartridges.
Posted on Mar 21, 2008
How do I trouble shoot a HP printer 4500 G510n-z copier feature doesn't work.
Have you tried this? Turn the printer off. Then turn it back on. After it settles, with the right/left arrows adjust the indicator in the control panel window to either black/white copies or color copies. Place paper on scanner window and press the OK button. It should print the copy.
Jan 28, 2015 | HP Office Equipment & Supplies
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
Print is not dark on half the a4 paper and ok at the rest of the paper
check transfer roller, take a test print from service mode( * 2 8 * > copier> test>pg>07>ok>copy start) if it is ok then the problem is in the scanning area, clean mirrors, check ccd.
Dec 12, 2010 | Canon imageRUNNER 400S Copier
Power button flashes and display says shutting down but it won't turn off and is unresponsive to pressing the power button. This happened after I tried to copy something but it froze halfway through the...
turn on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck .
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for trouble shooting problems
hope this helps and good luck
Apr 28, 2010 | HP Photosmart C4480 All-In-One InkJet...
My printer keeps on saying align cartridges and I do. But once it finishes it just go backs to saying the same thing! And yes it says it passed.
turn printer on/off, unplug, plug in, should reset configs.
check the rollers to make sure no paper or particles are stuck.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome web site for trouble shooting problems
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jam, paper feed issues
dear sir good day this printer have a common problem in the separation pad part and it need to simply replace ... so please take your printer to the tech company to replace it for you or buy it from it ((mention the printer model for the co.)) and download the service manual from the printer manf. site and do simply install the spare part and it'll work thank you
Jan 08, 2010 | HP PSC 1610 All-in-One Printer, Scanner,...
HP4L Printer-While printing,paper cycles1/2the way, printer stops
Check the paper size setting in the software and print driver. Sounds like a non-standard paper size setting.
Feb 15, 2009 | HP LaserJet 4L Printer
Black ink
You may want to do the ff. just to make sure your printer is physically functioning.
1. Disconnect the printer cable that is connecting printer to the computer.
2. Turn the printer ON by holding down the POWER button for about 3 seconds.
3. Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4. Press the Up or Down arrows to select NOZZLE CHECK. Press the OK button,
then press OK to print a nozzle check.
5. The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6. To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the Nozzle Check Pattern page does not print, prints out with gaps in it or some of the colors do no appear, then there is an issue with the printer. That means that troubleshooting is required on the printer prior to using printer on the computer.
If the Nozzle Check Pattern page prints correctly and completely, the problem may lie within your software settings, the interface cable, or your computer.
according to the manual, goodluck!!!
Apr 26, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
HP2355 PSC
Feb 03, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
Ben Johnson
