Question about Maytag MTB2176HRS Top Freezer Refrigerator
Maytag MTB2176HRS not cooling
My Maytag refrigerator MTB2176HRS is not cooling, there is no frost in the evaporator, fans and compressor is running. what is wrong with it? Please help
  • 958 Answers
It could be out of gas...can you open the bottom rear cover and feel the air coming out of the condenser blower. if its not warm, you have a leak where refrigerant escapes...
Posted on Mar 28, 2008
Refrigerator barely cooling and freezer part isn't cooling at all
Can you feel the compressor top to see if too hot to keep your hand there? Tell me if the fan is running next to the compressor and if the evaporator fan is running. If the compressor and fan are running normally I need you to remove the cover over the evaporator inside the back of the freezer and see what the frost pattern looks like. (provide photo of evaporator frost pattern)? I can help you find the problem if you respond to my questions. Hopefully this is only a start relay overload and run capacitor. Here is a list of parts=> http://www.repairclinic.com/vwo7/Shop-For-Parts/a4b160d1067876/Model-RB195ACWP-Samsung-Refrigerator-Parts?sml=true?RCAID=35836
Try to upload photo here but if unable I will provide my contact info. Below is a photo of a refrigerator evaporator that shows that the refrigerator is leaking Freon. APPLIANCE 911 74bbe3be-3b56-4111-ae2b-7d0d2139a639.jpg
Nov 29, 2015 | Samsung RB195ACWP Bottom Freezer...
I have a Hotpoint HSS25GFPEWW side by side.....initially the ice maker stopped crushing and dispensing ice....then the freezer started to warm. I cleaned the condenser coils and confirmed the condenser...
dead if the compressor is running and theres no cooling or frost on the evaporator you have leaked out all your freon only way to fix is call a pro about 600$ to fix
Aug 15, 2012 | Hotpoint HSS25GFP Side by Side...
WRS6R3EW8 Refrigerator and freezer not cooling. Evaporator coil 60 deg. only. Compressor, evaporator fan and condenser fan running. Some frost on the tubing coming from condenser at the evaporator. ...
Where is it frosting, condenser or evaporator? If you mean frosting on evaporator line to compressor, probably iced up evaporator. If you mean frosting after condenser by capillary, unit short of gas/ blocked.
Apr 27, 2012 | Refrigerators
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
May 25, 2011 | Maytag MSD2454G Side by Side Refrigerator
My refrigerator no cooling or my freezer
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jan 28, 2011 | Maytag MSD2651 HE Side by Side...
Unit not cooling down,compressor running,condenser fan running. suction line just cool,condenser line barely warm.
Check if evaporator fan is running. Is there any frost buildup on freezers evaporator cover? If so you have a defrost problem (bad heater, defrost thermostat, thermister, defrost timer or circuit board ). If no frost and the freezer is warm then you most likely have a sealed system problem(leak, restriction, bad compressor) which is costly to repair.
Oct 19, 2010 | GE Â 17.9 Cu. Ft. Top-Freezer...
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
How to check stuff>
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Frigidaire Refrigerator not cooling
Is the fan on the bottom on? Do you hear the compressor kick off and on within a minute? No/ Is the evaporator fan running? Do you have frost on the evaporator? Frost is a sign that the defrost isnt working. If evap fan doesnt run it wont cool the refrigerator. If everything is running and no frost buildup in freezer then you have a sealed system problem and need of a tech.
Jul 25, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore Refrgierator is not cooling enough
Is the frost on the entire surface of the evaporator or just a portion. If it is only frosting on a portion there is a possibility your system has developed a leak and has lost some of the charge. Or your compressor has lost its ability to pump the gas. A bad condenser fan motor overtaxes the compressor and can cause premature failure. If it is a bad compressor it may be time to replace the refrigerator. Replacing the compressor is an expensive job and the warranty is only one year on a replaced compressor.
May 31, 2008 | GE Profile PSW26P Stainless Steel Side by...
Maytag MTB2176HRS Top Freezer Refrigerator Logo
253 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
