Question about Panasonic SC-HT730 System
Panasonic sa ht530
My dvd home surround system has just gone off with f61 on the display screen what could the problem be and how can i resolve it
  • 3 Answers
REPLACE RSN IC(SOUND AMPLIFIER THEN CHECK AND REPLACE 2 -3 SMALL TRANSISTORS TWO 2SC3199 AND ONE 2SD592 THEY RE ON THE AMPLIFIER BOARD,EVEN WHEN RSN IC IS REMOVED SHOULD NOT SHOW F61 AFTER YOU'VE REPLACED THOSE TRANSISTORS
Posted on Feb 06, 2009
  • 682 Answers
Check and correct speaker cord connection-after checking that everything in its place and no wire touch each other .
disconnect all speaker cords and connect it one by one while you play any music until you connect one who make the problem change its cord with new one and connect it firmly in its place.
Posted on Apr 04, 2008
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
May 12, 2010 | Panasonic Home Theater System System
My panasonic SA-AK57 it is displaying error code F61
you need a code 234634
it is wary simple to fix
if the code dosent work the there is
Jun 22, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT530 has all key locked
hi sorry for my english ,but i got the solution try to read this carefully.
While stopped and “DVD/CD” is the source, press and hold [] on the main unit and [S10] on the remote control until “Initialized” disappears from the television. Turn the unit off and on again. default will begin. s10 is the buttom 10 (enter) in the remote control. i hope you will fix it . Alejandro Rosas . from Coyhaique ,chilean Patagonia
Oct 06, 2008 | Panasonic SC-HT730 System
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
Jul 15, 2008 | Panasonic Home Theater System System
Panasonic SA-HT940
F61 is a problem with the output amplifier pac. It is the equivalent of "protect" mode. The output pac needs to be replaced. I'll look up the part number for you.
Dan
May 14, 2008 | Panasonic sa-ht930 Home Theater Audio...
I have a panasonic dvd home theatre system SA-HT530 and i can't get the sound to work i use to be able to change the setting on the remote using super surround but now it wont work and all i have is the...
check audio out cables ( usually white and red ) unless HDMI.
Also see if theres another alternative output socket.
If non of these resolve your problem, possible audio amplifier/fets damaged.
Mike @ compurepair.
Apr 03, 2008 | Televison & Video
F61 code
yes i did see this code F61  but turned off and back on and the surround and center speakers still don't work
Jan 06, 2008 | Panasonic SC-HT720 System
How do I solve Panasonic SA-HT800V error code F61?
unplugged a Panasonic HDTV plasma for four minutes, plugged back in and Now the DVD does not work.
How to reset?
Aug 28, 2007 | Panasonic sa-ht800V Home Theater Audio...
Panasonic SC-HT730 System Logo
395 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
