Question about KitchenAid KGRA806PSS Gas Kitchen Range
"Lost Communication" error
Error code F6 E4. When put into diagnostic mode, most recent code 0164
Please help.
  • 1 more comment
  • toopatient2 Jun 04, 2008
    I bought a new control board thinking that the problem would be fixed, as it a had a different revision number.
    Well, sort of. If I plug my range into a non-perfectly grounded electric outlet, it shuts off every time.
    If you continue to have this problem call an electrician to check to see if the outlet is properly grounded.
    I also noticed on the original board most of the solder joints looked questionable and two of the four capacitors appeared to be "stressed".
    IF YOU ARE NOT FAMILIAR WITH ELECTRONICS DO NOT ATTEMPT TO FIX YOU OWN CONTROL BOARD!.
    I should have replaced all four capacitors, but I got nervous and bought a replacement "control center" as it is called.
    I can almost guarantee you if your oven gives the "lost connection" often, you have a grounding issue at your house.
    Why am I so adamant? Because I bought my range used after it was diagnosed by the factory technician the house it was in wasn't properly grounded and was causing the problem.
    Of course, they didn't that out right away...
    Also, the control board is sensitive to old exhaust fan motors like I have in my 50 year old house. Even in a properly grounded outlet, if I turn on the exhaust fan above the stove it shuts down.
    I hope this helps somebody else with the same problem.
    Granted, I figured there might be more to learn about my stove paying $200.00 to buy it used from the dealer after testing the self-clean sensor and replacing it.
    So I'm into an $1800.00 range for $300.00 and I'm okay if it's finicky because I know how to fix it and i'm still $1500.00 ahead.
  • toopatient2 Sep 09, 2008
    I replaced the control board in my oven, with a different revision board and guess what? It did the same thing. Same error, same difficulty. The timing circuit on these ovens is still poorly designed. But, here's a BIG help: if your range has been plugged in for any length of time (like normal) before turning the oven on "bake" unplug the oven for 5 minutes, then plug it back in and it doesn't throw any more error codes. Of course every time you want to use the oven you need to unplug, wait, then plug it back in. At least there is a way to fool the oven into working. My range is plugged in in a wall outlet above it, so it's easy for me to do this. I might suggest for other people with this same issue get a properly sized extension cord, a short one of course, and try my "fix" it's not perfect, but at least now I can use the oven again without having to watch it every minute...
  • kdqrn Jan 03, 2009
    I had the same problem. If I reset the circuit breaker the error message/problem disappers and the oven will work.
    Are more users of this oven seeing this problem?
    No grounding issues since I have checked electrical and confirmed that plug is indeed grounded. This communication error occurs infrequently but when it does it's annoying.
3 Suggested Answers
  • 4 Answers
SOURCE: kitchenaid gas range KGSA906PSS
Google kitchenaid error codes...
I have had three ranges and at least five circuit boards so far... they are garbage, if under warranty, call and complain LOUD.
Posted on Jan 31, 2008
  • 2823 Answers
SOURCE: error code F6-E4
Igoogled this all i could find wea control panel fault nothing for e4
Posted on Feb 08, 2010
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Whirlpool dishwasher error code f6e4
F6 error fault code...
This is the Water tap closed. What that means is that the flow meter is not recording water entering the dishwasher, this can be a water tap turned off (suprisingly more common than you'd think, after new flooring or decorating has taken place),water hose kinked or blocked, the dishwasher water soleniod valve defective.
Dec 18, 2013 | Dishwashers
F6 E6 error code?
This fault is a communication error at the appliance manager, could be a loose wire or a bad display transformer, either way you will need a certified technician to fix this issue, there is no simple plug and go issue to resolve. I personally found the problem to be the transformer not send voltage to the appliance manager. This is solvable but needs someone who understand electronics to correct this issue.
F6 E0 Oven user interface - lost communication E6 Oven appliance manager 1 (upper, single) - lost communication
This is directly from the tech sheet of your oven and directly from the factory web site.
Good Luck
Dec 03, 2013 | KitchenAid KEBS179B 27" Built-in Electric...
Whirlpool Accubake Range - error F6 E4 , how do I stop the beeping
Replace the sensor as shown in the F6 code
F6 Computer logic interrupted (timing) Replace Electronic Range Control (ERC)
Error Code: E4
Cause: Shorted sensor
Example: Disables cooking in affected oven
Corrective Action: Check sensor
Nov 02, 2010 | KitchenAid KESC300 Electric Kitchen Range
Error code F6-E4
Dec 11, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kitchenaid gas range KGSA906PSS
Jan 17, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
491 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
