Motorola Mobility HS850 Consumer Headset Logo
Posted on Apr 19, 2010
Can i listen to music using motorola hs850? - Motorola Mobility HS850 Consumer Headset
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
1helpful
Need the code to pair my blue tooth motorola
Try using 0000 as it's the basic code for every bluetooth unless manually change. That is the factory default.
I have a n136 head set and i can't get it ta pair with my Lg music, can anyone help me?
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
4helpful
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
12helpful
Won't pair with Motorola HS850 headset
Having problems pairing
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Motorola HS850-
almost all of moto bluetooth headset get this problem. i think H680 is much better that HS850 or H700. i'm using RAZR2 V8 and almost all BT headset have static problem. So i end up with korean's and french's BT headset which have much lower static.
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
