Question about Sony PlayStation 2 (PS2) Console
Ps2 stuck on memory card screen
When ps2 disc is inserted, it says reading disc, then goes to the memory card screen and stops
    Scholar:
  • 102 Answers
9 out of 10 times when the fat ps2 cant/wont read disk its the cd tray needs to be adjusted.
I would suggest opening up the ps2 and cleaning the console with Qtips and rubing alcohol. if the laser will wont read. go to youtube.com type in fix my ps2 laser. you will watch a video on how to adjust your cd tray.
The reason for this issue is if the laser is to close or to far from the cd the laser cant read the cd.
the worse problem u can come across is the laser 100% failed. which is rare but you can buy a new/used working laser on ebay.com or google it. the laser will have the model on it you want to make sure you get the correct model. otherwise it wont work.
contact united.gamez@gmail.com for help
Posted on May 20, 2008
If its not an original disc, meaning if it was copied or burnt, then this will happen. However if it is in fact an original PS2 disc, then I'd suggest taking it out, cleaning and trying again.
Posted on Mar 21, 2008
I bought a new ps2 and a datel 32mb card and the game i put in says there is no memory card,
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
  1. Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
  2. Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
  3. Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
  4. Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
    If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Dec 31, 2010 | Datel Max Memory 32MB Memory Card
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
PS2 wont read discs
This is optical lens assembly failure. you will need to replace this failed assembly in order to restore the normal functions.
Contact Sony for this repair.
Jun 21, 2009 | Sony PlayStation 2 (PS2) Console
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
Jun 13, 2009 | Sony PlayStation 2 (PS2) Console
PS2 won't play disc
sounds like 1 of your lasers is damaged. its a common problem as there are 2 lasers on this model.
Oct 26, 2008 | Sony PlayStation 2 (PS2) Console
Why doesnt my PS2 read Twisted Metal Black?
Try cleaning the disc and the lens or try a diff disc and see if that plays. if it does your cd's busted.
Jun 08, 2008 | Sony PlayStation 2 Slimline Console
Ps2 problem
i have had the same problem and i just kept using my disc cleaner and polisher and after a few times it work. if that didn't work get a laser disc cleaner for your ps2
Feb 05, 2008 | Video Game Consoles & Games
Ps1 disc playing in ps2
Are you inserting a PS2 or a PS1 memory card?
PS1 games can't use a PS2 card because they don't "understand" how to read them.
To save a PS1 game on a PS2 you will need a PS1 memory card.
I hope this helps, I assume this is what you are referring to with your question.
Dec 25, 2007 | Sony PlayStation (PS) Console
Disc read error
Your PS2 lens is faulty or it is physically jammed in it's metal rod which stops the lens to move smoothy. you better open the PS2 console and observe it offline for jam. or replace the lens with a new one.
Nov 15, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
677 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
