Tv not showing a picture
There is a white line in the middle of screen
  • 1 more comment
  • jaycee2u May 26, 2008
    We recently experienced a horizontal line with no sound. Sometimes either tapping on the cabinet or powering off/on may temporarily resolve the issue. Now, we do not event get the horizontal line or sound. We hear audible clicking when initially powering on.
  • Anonymous Jan 20, 2009
    I also have a white line accross my screen, it was only 13 months old when it started doing this. so i never used it , now after Divorce I NEED it. haha....it will work fine for about 3 minutes and then quit after warming up. Can i repair this myself here. I do electrical work with controls , what should I change out?and where do i get parts? Thanx Darren
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    vertical or horizontal? and does it go from one side of the screen to the other?
    Genius:
  • 1,139 Answers
Hello e26pitts,
If the line is horizontal then it could be a problem in your vertical deflection section, if the line is vertical then the problem is in your horizontal deflection section. Now for a little more detail.
If Horizontal line is present the vertical section of the yoke transformer is nit responding to current flowing through it due to being open, or the vertical coupling capacitor is open, or even the vertical drive transistor might be defective.
If Vertical line is present the horizontal section of the yoke transformer might be bad. Now this gets kind is easy in a way, because the yoke would be the sole cause of your problem here (maybe there is some circuitry doing some horizontal coupling check that to) because the horizontal section controls other functions that would also respond if this were a horizontal drive issue. In any event these problems should be checked by a qualified TV technician, I would suggest that you take the TV to a repair shop to have it worked on.
I hope this helps
Thank you,
Shuttle83
Posted on Mar 24, 2008
SOURCE:
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
TV HAS A COLOR LINE WHEN IS ON IN THE MIDDLE OF SCREEN
if it runs across the screen its a buffer board usually. Can you paste a picture of the line?
Mar 10, 2013 | Sanyo DP50747 50 in. Plasma TV
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
I have a white Verticle line but I get a picture
Have you tried unplugging the sat receiver and plugging it back in? This will reset it.
Dec 21, 2008 | Sony KV-32XBR450 32" TV
Tv cannot display only a line in the screen
for short circuit it will show  like this if no short circuit
i think ur tv display tube has dead if it is in warenty pls exchange the tv
Jul 31, 2008 | Sharp 25R-S100 25" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Ekse
