Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Red aura I have recently experienced the "blinking green light" problem with my Mitsubishi big screen and successfully replaced the damaged capacitors. The set powers up now but the picture has a red aura. Can you give me any help on this problem. Thanks.
    Sergeant:
    Champion:
  • 301 Answers
There is a small surface mount IC location num IC9C25 on the board next to the DM. it is at the bottom right corner if looking from the back. this a 9v regulator P/N BA09FP this might be your problem. be careful taking it off because you do not want to damage any traces. i suggest taking the input board off.
Posted on Mar 29, 2008
Mitsubishi big screen HD 1080 series model WS-55809. it switched off one day. and when i turn it back on it switches right back off. red light in front. what part do i need to fix it/
That model does not have a red light---Green.
If set powers up for a few seconds (green power light) and goes out do the self check the model indicated has:
On front of set (not with remote) press and hold both the input and menu buttons for at least 5 seconds and release both.
Green power light will blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it several times.
Let me know what error code you find (if you have unplugged the set that will clear all errors and you have to plug it in and try to turn set on again---when it fails do the self check)
Mar 31, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My mitsubishi big screen tv will not turn on
What is the status of the LED at the front? Does it change from green to red or blink or just stays red?
Dec 05, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I RECENTLY PURCHASED A 1994 bIG SCREEN TV ( mODEL # TP55C81 ) THE PICTURE IS PURFECT BUT IM SEEING THE RED GREEN AND BLUE LIGHTS . THE CLOSER I AM TO THE TV THE SMALLER THE LIGHTS ARE AS I BACK UP THE...
You have a projection TV - basically a red, green, and blue spotlight is shown onto the back of an opaque screen that creates the color picture you see. The spotlights you are seeing is common for a TV of this vintage and type.
According to the user's manual, you should ideally be sitting no closer than 10 feet to the screen.
Sitting closer to the screen may enhance the phenomenon you are experiencing.
Nov 19, 2009 | Toshiba Televison & Video
IMitsubishi 62525 timer light blinks green and won't turn on
Try a system reset by unplugging the set and waiting for about 3 min then replugging it in. If this problems persists contact mitsubshi for technical support, I have replaced entire signal board chassis for this same problem, they will run you through a few common things to try using the front panel buttons.
Sep 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
My panasonic big screen wont turn on
find out if someone can push the rest button on the side somewhere in a certain sequence
Feb 07, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi Big screen problem
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
May 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
66 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
