Question about Maytag Neptune MDE5500AY Electric Dryer
DRUM/TUMBLER ISSUE I have a maytag MDE5500AYW dryer, the tumbler or drum looks to have come off track..the drum or tumbler will still turn but clothes have got torn between the drum and rear wall of dryer..can and how can this proble be fixed..thanks
  • Anonymous Apr 08, 2008
    drum paddle that tumbles clothes inside drum are loose how can i get to it to tighten screws?
  • apple44 Apr 25, 2008
    I have the same problem with a drum paddle inside drum. I don't know how to get inside to tighten the screws?
  • 958 Answers
Look at the rollers of the drum, it could have been dameged already and needs to be replaced.
Posted on Mar 28, 2008
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
Maytag dependable care quiet plus ii
Hi, The belt should be in a straight line from the motor to the drum.
If alignment is not corrected damage to belt may occure.
Normally if all parts are working properly the belt should align itself.
Make sure that belt is not rubbing on any other parts. (slowing motor down). Lube all moving parts with lube oil. Don't put oil on belt.(only on bearings of motor and drum).
Jan 20, 2014 | Dryers
Dryer is making a"knocking" sound
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 25, 2010 | Dryers
The tumbler makes a terrible noise - I'm sure it's just a coin or a screw rattling around in there. I can't figure out how to get inside to look around the tumbler to see what it may be. And once...
Open the door and look inside - yes, you can see everything inside the drum. Sometimes buttons, especially the metal ones on denim pants, can make a pretty good racket.
If you don't find any foreign objects inside the drum, and the dryer makes noise even when it's empty, it may be time to change the drum rollers or the belt tensioner pulley. It's also remotely possible that there's something batting about in the blower housing, but if that is the case, it would probably be a screw or something broken off of the ductwork, or the blower itself is loose on the shaft. Post back if you need instructions for checking the mechanism underneath the drum.
Nov 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
We have a Maytag Electric Dryer, Model LDE512 , which leaves black marks on clothes while drying them. The dryer is about 18 yrs. old and has been working great except for this one problem. We have...
HI The drum is mostly stainless steel; The end that contacts the drum guide is just painted steel. After years of rubbing, some rust can form after the paint wears away,thus, causing the stain. Painting the bare metal (after removing all rust) and replacing the tumbler bearings,roller and roller shafts, will correct this issue and prevent it form happening in the future. You should also replace the tumbler seal while the unit is disassembled. Part numbers are below:
Tumbler bearings/Glides(You need two)- 306508
Roller - 12001541
Roller shaft - 6-3129480
Tumbler seal - 314820
Roller Shaft washer - 312535
Retaining Ring(shaft)- 410233
Jul 16, 2010 | Dryers
I have a Neptune electric dryer model MDE4000ayw. The clothes keep getting stuck around the barrel as the dryer is operating. What is the problem? It also makes a very loud noise as it operates.
You need to disconnect the dryer from power source, open the unit, it sound like the drum has holes on it that stucked your clothes when turning. this problem common to all maytag dryers. The front support glide had chop up . You might likely change the drum or tumbler.
Comment if the solution solve your problem
Dec 06, 2009 | Maytag Dryers
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Electric dryer makes a rumbling when tumbler is turning.
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.The bearing is at the base of the drum and accessing it is not easy.
You can find diagrams and replacement parts entering model number here.
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
REPLACING BELT
Hello, This is somewhat involved and time consuming, but if you are handy, it can be done. First unplug the dryer then start with the two screws in the hinges of the door and then the door lifts out. Two screws on the opposite side holding plastic spacers. Once these four screws are out the front panel tilts right out. The front panel will come off then 4 more holding on the front tumbler support and air duct. Removed wires from light and dryness sensor and clips holding wires to panels. Pull out the tumbler and removed belt. If your dryer gets a lot of use, then you might want to keep going and replace some more wear items while you have it apart. Remove the two drum support rollers and shafts by removing a nut on the back side of each shaft. Remove snap ring off each old shaft, install new rollers and fiber washers onto new shafts, reinstall snap ring and replaced on brackets with the old nut. Remove tension spring off idler pulley bracket and one screw holding on the bracket. Install new pulley and fiber washers on new bracket and reinstall bracket and spring. Placed new belt on tumbler and reinstalled tumbler. Used drill and bit to drill out pop rivits holding on the two front glides that are attached on the front tumbler support and installed new glides and pop riveted in. Reinstall front support and air duct checking that felt tumbler seal front and rear are in place. Placed new belt on motor pulley and idler pulley. Reinstall front panel.
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
302 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
