Question about BonJour 7001-17 Caffe Froth Eiffel
Bonjour Caffe Froth plasatic part broken
I have a Bonjour Caffe Froth that made great froth until the plastic bottom broke, the part that fits on the nut which secures the screen in place. Everyone has replacement carafe but not that little clear plastic part.
My frother fell apart.
What order do these parts fit back together?
Am I missing a screw on the bottom.
Lost, any help out there?
Posted on May 28, 2008
Same thing happened to me????? I don't understand. Have you goten yours back together yet. I JUST bought mine.
Posted on Sep 19, 2008
How do I make cold froth on my aeroccino for my lattes?
Press the and hold the button for 5sec or longer until the light turns blue. That will get you cold froth.
Jun 27, 2010 | Nespresso Aeroccino Automatic Milk Frother
Milk won't froth
have you tried pumping loads of water through the frothing device. it worked for mine.
Jan 17, 2010 | Breville ESP8XL Espresso Machine
My Krups XP4050 frother heats and makes bubbles but no froth
It doesn't froth because the air hole in the frother has become plugged with dried milk (cream). There are two types of frother - old one was a black rubber nipple with a stainless 2-3inch air tube rising above the milk. The plastic insert has a pin hole (really about the size of a straight pin!) that clogs. Use a sewing needle or straight pin to clear it.
Apr 01, 2009 | Krups XP 4050 Espresso Machine
Milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Aug 29, 2008 | Saeco Talea Giro Espresso Machine
Seaco Odea Go
You can not adjust the amount of this.
/Mirran
Aug 17, 2008 | Saeco Odea Go
Too much froth
Does this happen after you make several froths or the first time you start the machine? Try removing the panarello and froth milk that way then see if this is happening too without the panarello. I found that panarellos are great as a "quick learning to froth?- but they do have the tendency to froth milk too much without heating it up ( to the temperature that you like).
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
Froth control problems
Your vinegar did the job: it as removed the deposits, now these deposits are clogging the four holes porcelain valve.....if the froth lever is not broken.
Remove all the screw you can see on the top and under the top of it, remove the cover, unscrew the frothing device down to the porcelain valve consisting of two 4 holes discs, clean them, and voila!
Dec 22, 2007 | Krups XP 1500 Espresso Machine & Coffee...
Frothing tube
Sheryl,
It sounds like the tube is clogged.  Remove the silver tip on the bottom of the tube.  Hold it up to the light and see if you can see through it.  If you can not, take a tooth pick and clean the tip out.  This seems to have worked for mine.
Adam
Aug 26, 2007 | Mr. Coffee ECM10
BonJour 7001-17 Caffe Froth Eiffel Logo
454 people viewed this question
Top BonJour Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a BonJour Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
