Question about Tascam Audio Players & Recorders
Tascam DA45HR load error
Load error on tascam da45hr causing machine to crash.I hear this is common, any ideas?
What does code LE mean
Load Error
Most commonly caused by a bulky or off balanced load set to spin at too high a speed. (low speed spin required for those loads) If not a load issue, the next most common reason is a bad Hall sensor (located on the motor windings. easy replacement, and part is covered under the 5 or 7 year motor warranty) After those causes, next on the list, could be a stripped out spline on the motor rotor, the shaft of the drum drive spider could have broken loose, there could be a poor electrical connetion or bad wire between the Hall sensor and the main board, the main board could be bad, well, you get the idea. You may need a service call if it wasn't a load issue.
Apr 03, 2011 | LG WM-2077C Front Load Washer
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
I have a Tascam CD-01u CD player that has a CD that will not eject. It will play the CD, but only clicks a lot and displays "Error 2" wihen I attempt to eject it with the remote and/or the machine's face...
I have a Tascam CD-1u Professional that load's the CD and say nodisc once it is done loading. this unit dosen't seem to be reading the CD what is the problem
Oct 16, 2009 | Tascam CD-01U CD Player
TASCAM DP-004 - SD card file access error
Stick the SD card inside your computer, if your computer does not have the hook up for it, Radio shack or Best buy can help you with that. Then you can save the files on your computer, then re-down load them back on your dp 004. But if your card is reading error then maybe you would have problems trying to move them your computer too. Bryan
Jul 05, 2009 | Tascam Audio Players & Recorders
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Looking for some further insight into 'Error 03' messages
HI...
The unit will need to have the cover pulled off and the tape drive mechanism unfastened , turned over and,the VERY small belt needs to be replaced
SBO1.55 belt from www.studiosoundelectronics.com
Mar 20, 2009 | Tascam DA-30MKII
Tascam DA 40 DAT Machine ." Loading error "
The DAT machine needs new belts and maybe some cleaning. These fail all the time due to old belts that lose the tension that is required.
Dec 10, 2008 | Tascam 122MKIII Single Dual Cassette Deck
No HDD:20 Please PWR OFF
It means the harddrive has crashed. I have the same model. It is a manufacturer flaw. You can try saving your recordings on external devices or contacting Tascam directly.
Oct 05, 2008 | Tascam DP01 All-In-One Recording Package...
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
60 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
