Question about Baby Lock Ellure
Serger/sewing machine I have a ellageo babylock and the top thread is wrapping around the bobbin and stopping my machine. what can I do to fix it?
  • 24 Answers
You probably are in need of a new bobbin case they are plastic and oif you have broken a needle lately it may have gouged the case and the top thread is getting caught and bunching up underneath. Visit you can contact them and have a bobbin case sent to you.
Posted on Aug 13, 2008
It sounds like the lower shuttle is out of place. You should be able to take out the bobbin case and unlatch the shuttle. It will probably be in 2 pieces. Clean out the dust behind it and replace the shuttle pieces. You may have to fiddle with it a little to get them back in place. Then you can test it by manually turning the wheel. Make sure the bobbin is placed into the bobbin case and that the bobbin turns in the direction that you pull the thread.
Good luck.
Nov 11, 2014 | Brother Disney PE-180D Computerized Sewing...
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
presser feet tutorials,
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 | Sewing Machines
Thread presser foot juki serger
try a new needle
rethread the machine top and bobbin
make sure the bobbin is not warped or damaged
make sure the bobbin is inserted in to bobbin case correctly
clean under the needle plate and in the bobbin area for lint
if the problem still happens,, then it would be a good idea to have the machine checked for a timing problem
Sep 28, 2013 | Sewing Machines
How to wind bobbin on white 1418
1 Release the stop-motion knob on the right side of the sewing machine by turning it oward you.2 Place a spool of thread of your choice on the spool pin located toward the back of the sewing machine.3 Pull thread from the spool through the threading knob on the top of the machine.4 Pull 2 to 3 inches of thread through one of the holes on the bobbin. Hand-wrap thread around the bobbin in an anti-clockwise direction five or six times.5 Place the wrapped bobbin on the bobbin spindle.6 Push the winder spindle to the right, against the stopper, and depress the foot pedal to begin winding.7 Wind bobbin until completed, then return winder spindle to its original position.8 Tighten the stop-motion knob.
Oct 14, 2011 | White Sewing 1418 Mechanical Sewing...
I can only get a small amount of thread wound on the bobbin.It stops and wont take any more. The bobbin case keeps moving & I cant get it back in correct place
I assume you are placing the bobbin at the TOP of the machine, then wrapping the end of the thread several times around the bobbin in a counter-clockwise motion?
Have you made sure to "scoot" the empty bobbin next to the bobbin bar to the right? Is the thread going from your spool, directly TO the bobbin? Because it is supposed to wrap around the tension "nut" (where you start to thread your machine) before going to the bobbin.
Apr 24, 2010 | Brother XL-2230 Mechanical Sewing Machine
Babylock seger machine keep breaking the left side needle.
Try rethreading the machine, and make sure the thread is not wrapped around anything. Then check the tension for the needles. Run a few inches of chainstich off slowly, while watching the thread and loopers make the loops over the finger. Your threads may be in the wrong position, or underneath the wrong parts to start.
Jun 12, 2009 | Baby Lock Eclipse Serger
Embroidery bobbin problems.
Each manufacturer have their own bobbins.......not interchangable
Apr 28, 2009 | Baby Lock Sewing Machines
Top thread wraps around bobbin
Is it birdnesting under the bottom or it is actually getting tangled inside the bobbin case? I've had my machine for almost a year and don't think I've had your exact issue. Sometimes, when you do a stich over a already stitched portion, you may have a problem with the bobbin and I just generally stop and start it again. It is important that you use the correct needle and also use a good embroidery thread and stablizer. Another thing suggested is changing the needle after about every 5 designs. Also, check the bobbin case to make sure there's no fuzzies caught in it. I use "canned air" like you use on computer keyboards. I also only use 40 weight emboidery thread for the top and actual bobbin thread for the bottom. Other threads can really jam everything up. So it's been trial and error to find the right combinations. Good Luck!
Oct 30, 2007 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
175 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
