Zune will not turn on
My zune will not turn on when I push the play button. When I press the play button the zune logo flashes and then the zune turns off.
It is fully charged and comes on when connected to the computer. Sometimes when it is connected to the computer it continously resets.
    Genius:
  • 1,027 Answers
Disconnect from PC.
Make sure the Lock Tab is not engaged.
Press and hold the (BACK) button while pressing up on the control pad. This will allow a system reset. If the firmware is not corrupt then the system should operate normally.
You may have to attach the zune to your pc after downloading the software from this link. Zune supports auto-update features.
Posted on Mar 21, 2008
    Guru:
  • 731 Answers
I think we should update the Firmware version.
Click here to download and to update the firmware
Note:Zune Sync cable should be connected to the PC.
Download
Thanks
Riz
    Genius:
  • 3,422 Answers
Have you tried resetting it?
Press and hold the back button while pressing up on the keypad.
Goodluck.
  • 796 Answers
1. If the Zune device is not connected to a power source, set the Hold switch to unlocked. Then, press and hold the Play/Pause button to turn off the device. • If this does not work, restart the device. To restart the device, set the Hold switch to the unlocked position, and then press and hold the Back button Zune will not turn on - zune_button_back.gif as you press the top of the Zune Pad. When the device begins to reset, you can release the buttons. 2. If the Zune device is connected to a power source, it is operating correctly. You cannot manually turn off the Zune device. Note Depending on how you configured your backlight setting, the backlight for the Zune device may automatically turn off in this situation. To access the backlight options, select display on the settings menu, and then press the center of the Zune pad. To adjust the setting, select backlight, and then press the center of the Zune pad.
  • 4,889 Answers
Hi! DId you try a complete reset.. just take the battery out and leave it like that for about 1 min. Then put the battery back and see if it works. If it doesn't then try connecting it to an outlet and then try to switch it on. IF it works then its a battery problem.. If it still doesn't work then you can try updating the firmware to a later version and see if it works.. report your findings so that we can proceed further
  • eagle338
    eagle338 Mar 22, 2008
    Hi there did it work?
Have a zune 120g thqt displays a 5 and zune player with a X in the screen. And it says to contact support. It wont cut off or reset it wont do anything at all.
hold the back button and the up button until you see the Zune logo then release. if this doesnt work then you are going to have to reset your Zune....however this will loose all the data on the zune so your music/movies will be completely gone. you are going to need to press and hold the back and up button until the zune logo appears then hold the back,play/pause, and the center button until you see "please wait"
if this doesnt work you have some serious issue.Source(s):
Sep 08, 2011 | Microsoft Zune JS8-00001 Digital Media...
Error code 5 and 3
if this doesnt work you have some serious issue. Contact customer support
Sep 05, 2011 | Microsoft Zune JS8-00001 Digital Media...
Have a 80 GB Zune. It froze one day and was showing the message 'Connect the player to your PC'. I did that but then some error message started appearing in the Zune PC software. I tried formatting the...
Try the reset procedure...
Jan 02, 2011 | Microsoft Zune JS8-00001 Digital Media...
My zune just stopped working
run the battery completey dead or you could possibly reset the device to factory default...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 22, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Want to put music back on my zune,it wouldn't sinc,
May have to reset the zune to factory default settings...
Try this....
Hope this helps!
Mar 12, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune wont charge
unplug the zune. hold the back button and hold the up button until the zune restarts. wait until it turns back on. open the zune program. then plug in your zune. it should work.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune Light won't come on
All else fails try resetting device to default settings and reloading everything...
Try this....
Hope this helps!
Nov 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune sucks
Try this....
Hope this helps!
Oct 23, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Flashing Zune Logo
Had same problem - flashing logo when connected to pc; buttons not working when disconnected. Tried new cable (purchased for just over £6) - working fine now ! Maybe worth a try ?
Oct 09, 2007 | Microsoft Zune JS8-00001 Digital Media...
263 people viewed this question
 Grubhead
Grubhead
