I know this is a simple question (I think)
Eforcity 7 port powered hub not being recognized on the computer I want to use it on. It is recognized by another computer I do not want to use it on. I think it has something to do with the cable. Where can I find some kind of driver to put on the machine I want to use it on?
  • Anonymous May 11, 2010
    USB hubs don't require drivers (we are talking about a USB hub?). Can you give more details about the OS and age of the computer?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 194 Answers
Is it usb hub or directly connected to the network
if connected to the network check the lan card drivers or check if it is disable or enable
Posted on Mar 22, 2008
SOURCE:
The computer can not recognize drive (unknown USB device).
Method 1 - Unplug Computer So how did I finally fix the problem? Well, if you are lucky, it's a super simple solution! Try this method first and if it works, you'll have saved a lot of time.
Simply unplug your computer from the power supply. Yes that is it! Note that this does not mean just turning off your computer using the power button because most modern computers don't actually turn off completely and the motherboard will still get power. This is useful sometimes if you want to remotely wake up a computer, etc.
The motherboard is where all of hardware of the computer connects to, including the USB ports. Sometimes the motherboard needs to be "rebooted" because things can go wrong, i.e. all or some USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should hopefully be recognizing devices again.
So first turn off your computer using the Shut Down option in Windows or pressing the power button and then UNPLUG the PC from the wall outlet. Let it sit for several minutes and then plug it back in.
Method 2 - Update Device Driver If Windows is not able to recognize the device, you may also see in Device Manager that the device shows up as an "Unknown Device". You can get to Device Manager by clicking on Start and typing in devmgmt.msc or by going to Control Panel and clicking on Device Manager.
In that case, you should right-click on Unknown Device, click on Properties, then the Driver tab and then click Update Driver.
If this doesn't work, you can also try to download the driver for your device from the manufacturer's website. If the USB device is just a flash drive, then it's probably not a driver issue. However, if you are installing a USB printer, drawing pad, etc, then it might be worth downloading the driver for that specific device.
Method 3 - Restart & Disconnect USB Devices The next thing you can try is to disconnect all USB devices and then restart the machine. once you have restarted, try to connect the USB device that was causing the problem.
If that particular USB port doesn't recognize it, try another one. If the device is recognized by a different USB port, there could be a hardware problem with one of the USB ports. If no USB port recognizes the device, then keep reading because it's probably something else.
Method 4 - USB Root Hub Another thing you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties.
Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box. If you have more than one USB Root Hub listed, you need to repeat these steps for each one.
Click OK and then restart your computer. Try to reconnect the USB device and see if it is recognized. If not, go back to the power management tab for each one and check the box again. If it does recognize the device, then leave them unchecked.
Method 5 - Connect Directly to PC A friend of mine ran into this issue and the cause ended up being his USB hub. He only had three USB ports on his computer, so he bought a hub where he could connect an additional 8 USB devices.
I guess this proved too much for his computer and it just started sporadically not recognizing various devices. After removing the hub and connecting the device directly to the computer, it worked just fine.
We haven't really been able to find any other solution to this problem other than reducing the number of items connected to the hub. Actually, one other solution worked, but it meant having to buy a new USB hub with more power.
If you are having this problem with Windows 8 or Windows 8.1, then you might be in luck. Microsoft has released a fix for Windows 8 not detecting USB devices properly. Make sure to install this hotfix if running Windows 8.
Method 6 - USB Troubleshooter If nothing has worked so far, you can download the Windows USB Troubleshooter Fixit tool. It's a free tool that works with Windows XP, Vista and 7.
You can either have the troubleshooter fix the problems for you or select the fixes yourself. I would just let it fix them for you since the choices can sometimes be confusing and technical for the novice user.
Method 7 - Update Generic USB Hub If you are getting the Unknown Device error in Device Manager, you can also try one other thing. Open Device Manager and then expand Universal Serial Bus Controllers.
You should see at least one item called Generic USB Hub. On some computers, you might see two, three or more of these. Right-click on the first one and choose Update Driver Software.
When the update dialog pops up, choose Browse my computer for driver software.
Jul 10, 2015 | Transcend StoreJet 25 750GB USB Hard Drive
Im running win7, and it does not recognize this device which is a usb hub 4 port
A lot of times it won't recognize these devices until you plug something into them. Have you tried plugging in a flash drive, printer, etc to see if it's recognizing it but not showing it?
Jul 19, 2011 | Eforcity 4Port Octopus USB 20 Hub Black
When my computer searches for new hardware, it recognizes it and then installs it as "Unknown Device" The device still will not work, however, because when I check it in the device manager it...
This device should be recognized automaticaly by the OS. There are some issues with Windows 7, though.
Make sure you are trying to plug it in a 2. USB port, rather than 1.1. This might cause you trouble (even though this will not be a problem if you have a new computer)
Connect the hub to the external powercord. Sometimes it is not recognized because the hub cannot drain enough energy from the port.
if you are using a desktop pc, make sure it is plugged in the rear usb ports and not at the ones up front.
refer to the manual for further assistance: http://www.dynexproducts.com/cms/documents/DX-B4PORT-B7PORT_09-0962_QSG_V4_ENG_Final_lr.pdf
May 22, 2011 | Dynex 7-Port USB 2.0 Hub
I can't seem to get the Belkin 7-port hub to work with windows 7. Whenever I plug a flashdrive into it, windows 7 doesn't give recognize the flashdrive.
windows 7 is a 64 bit OS, and still fairly new. A lot of drivers for hardware are not supporting 64 bit Operating Systems yet, maybe in the near future but right now a lot are not.
Temporarily or permanently switch to Ubuntu. I think this hub is compatible, and you can still read your Windows files in this Linux distribution.
Dec 30, 2009 | Belkin (F5U237) 7-Port USB Hub
My computer does not recognise my Belkin 7 port hub.
sometimes the power it gets from pc fails but if it is powered alone check outlet or strip
Oct 04, 2009 | Belkin (F5U237) 7-Port USB Hub
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
Usb port not recognized: power surge on hub port
Your going to need a new logic board, I know only one place that fixes creative zen players and sells the parts besides ebay.
Apr 17, 2009 | Creative Labs Zen Vision Digital Media...
Western Digital Passport 160 GB external HD won't load.
WinXP SP2 blocks the use of the drive because it thinks it draws too much power. But there is a simple procedure to override this (from WD site):
"Problem:
Under Windows XP, an error message of "Power Surge on Hub Port" or "USB device has exceeded the power limits of it's hub port" is displayed when connecting a USB device to a USB port on a computer or Hub.
Cause:
Under some computers, USB devices are only allowed to draw a maximum of 500 milliamps (mA) per connection from the USB port on the computer system or from a USB hub. Under the Windows XP Operating System, with the release of Service Pack 2, if a device attempts to draw more than this (500 milliamps), a USB port balloon message is displayed to indicate this over current condition. When connecting a USB device that draws power from the USB bus, a very brief over current condition is sometimes detected by the OS, and the warning message is displayed.
Resolution:
This message has no affect on the functionality of the USB port. The USB hard drive should still function correctly on the USB port regardless of the error message. To prevent the USB Power Surge Alert message from displaying, please complete the following steps:
Click on Start.
Click on Control Panel.
Double-click on the System Icon.
Click on the Hardware Tab.
Click on the Device Manager button.
Click on the + next to Universal Serial Bus Controllers to expand the selection.
Right-click and select Properties on any listing that displays USB UNIVERSAL HOST CONTROLLER.
Click on the Advanced Tab.
Check the box that says: Don't tell me about USB errors."
This works fine, and the drive works fine afterwards. I suspect it actually draws less power than they say. Maybe it has a brief power draw spike on startup, but it's running power seems less. In any case, it works fine without the Y cable. I do think it is tacky that WD doesn't give the cable for free, since my $7 Sabrent 2.5" Hard drive enclosure came with a y cable.
But most likely the drive will work fine for you. It is a lovely quiet drive, and takes up no space at all.
Feb 01, 2009 | Western Digital Passport 160GB External...
My Laptop does not recognize Belkin 7-Port USB Hub(F5U237v1)
Try connecting it to another port or the one on the dock since some devices can be a bit picky about what port they get plugged into.
Mar 15, 2008 | Belkin (F5U237) 7-Port USB Hub
Open Questions:
Outlook MAil TelePHoNe {1-855*536*5666}#[email protected] NuMbER HAWAII This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 19, 2019 | AOL Computers & Internet
SBCglobal MAil SuPPoRt {1.855.536**5666}#[email protected] CALIFORNIA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
SBCglobal MAil PHoNe %%%{1=855=536=5666}#[email protected]@# NuMbER 24X7 This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
SBCglobal MAil help */*-+{1^/855~/536~/5666-}desk NuMbER PROBLEM This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Computers & Internet Logo
131 people viewed this question
Ekse
Alun Cox
