Back to:
Tags:
Dacor CM24P-1 Coffee Maker
Repeat error message (by 2 users)
posted by Robin8988 on Mar 21, 2008
My CM24P1 is suddenly repeating the error message, too much coffee.
There is not any more coffee than there ever was in the coffee bean container. I have temporarily fixed the problem by completely emptying the container but the solution doesn't last long. Every 4 cups or so I'm getting this message.
Any ideas on what my next move should be?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Lilyfish, posted on May 06, 2008
I've had the same problem a couple of times. I just open the machine, move the beans around a little and that seems to fix the message. If I had known how "high maintenance" this machine was, I would never have purchased it.
Best Solution
posted on Jun 07, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Lauralw1,
Let me know how the Miele does. A chef friend of mine said to me when I complained about the Dacor, "I'm not suprised, what does Dacor know about coffee? You should have gone Italian." Duh, what was I thinking? Anyway, do you ever have problems with weak coffee being dispensed after the machine has been on for a while? I can't get the %*&^#$* thing to make consistantly good strong coffee.I think I'll just stick to my Alessi Nespresso machine and the old standby french press. The Dacor causes me too much stress!
Rating Locked! (?) Robin8988 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Repeat error message:
I don't want to Accept this solution
Solution #2
Lauralw1
Rating: 70%, 1 votes
I've been through this with my Dacor coffee machine. I believe there is NO fix! Dacor replaced my entire plunger assembly and now it keeps sticking. The too much coffee error has gone but now I'm getting a persistent group error because of it getting stuck. I agree with "lilyfish" I wouldn't have purchased it either and to boot they have stopped making coffee machines!!! I'm looking at a Miele now.
Comment by Lauralw1, posted on Jun 12, 2008
to "Guest" please just email me and I'll fill you in on the whole story lauralw1 at gmail.com (in code) as I'm not sure they'll let me give out my email on this site.
Thank You!
Can you Help with these Coffee and Espresso Makers problems?
I have a CM24P-1 that will not dump the coffee cube after...
You can here the machine and it sounds like its going to...
Dacor CM 24P  we get the error "time out filling...
the piston or the metal pole below the cup that hold the...
I have a Dacor cm24p Coffee System and the water pump went...
Loading problems.
Repair Service
Find Coffee and Esp. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
