Question about Dryers
Electric clothes dryer
Runs for about 5 minutes then turns off. Will not stay running.
  • 30 Answers
The most likely cause is a bad timer. The timer determines how long the unit stays running (drying the clothes). A timer is typically $100-150.
Secondly, it could be a faulty motor. This part generally cost about $100-200 dollars.
Posted on Mar 21, 2008
SOURCE:
Samsung Dryer starts for 5 seconds then stops, but drying time still counts down.
I got the same problem and I tried to take off the belt let see the motor still running by itself but it still run for couple second then stop.
Jun 12, 2012 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
Dryer won't stay running, shuts off after a few minutes.
Maybe the timer or wires not hooked up right or motor if u hear like a buzzing sound when u push start it's the motor
Oct 30, 2009 | General Electric DWXR463EGWW Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
The gas dryer won't stay heated up.
Do you have stacked clothes on top of it or anything else? If so remove those items and never put anything on there. it's not a table it needs to be clear so heat can dissipate from cabinet. IF that doesn't solve it write bac
Mar 01, 2009 | Kenmore 73952 Gas Dryer
My dryer will not stay running when it has clothes in it.
Your motor is bad...they are famous for it...! As soon as it has some real work to do...It fails. If it runs for a minute or two...with clothes and no unusual noise...then it clearly the motor...
Nov 04, 2008 | Kenmore Dryers
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
check you vent hose all the way to outside. make sure not blocked or kinked.
Nov 02, 2008 | Dryers
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
