Looking for schmatic for vs60vf1
I have lots of burnt traces and resistors burnt beyond recognition in the area of Q4a04. Does any one have a schmatic of this area so that I can fix this set?
  • 5 more comments
  • Lee
    Lee Mar 21, 2008
  • Lee
    Lee Mar 21, 2008
    Yes Mitsubishi vs60vf-1
  • Lee
    Lee Mar 21, 2008
    I can not say. What I do know is that there will be no more troubleshooting on my part untill I can replace the burnt parts and do some trace reroutes on this board. I mean it is TOASTED. Once I have that rebuilt and rewired I can start in on other issues.
    But I am courious about this coolant leakage. Where would the coolant be comming from? And more importantly do you have the schmatic for this TV powerboard?
  • Lee
    Lee Mar 21, 2008
    I am trying to repair my self.
  • Lee
    Lee Mar 21, 2008
    Yes its a V12B Cassis. I know the locations but dont know the values.
  • Lee
    Lee Mar 21, 2008
    Troy do you have anyone that might have this schmatic? Can you ask around? It's a Mitsubishi VS60vf-1
  • Lee
    Lee Mar 21, 2008
    Excellent Thank you
    Genius:
  • 1,153 Answers
What your email address?
Posted on Mar 21, 2008
  • 3 more comments
  • Lashawn Robinson Mar 21, 2008
    Is this a Mitsubishi tv?
    This set is known for coolant leakage, do you think this might be the case?
    Have you tried pricing a replacement board, from PTS-18008447871? If that's possible or are you trying to repair yourself?
    I don't have a schematic on this model don't know why there is not one, correct me if I'm wrong but this is aV12b chassis right?
    No Schematic for me VS-67 no! If location number is visible maybe you could find parts replacement, but for board if burnt bad then may not be feasible.
    I will check on a few things and get back, check your email for info
SOURCE:
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
A transistor or resistor burnt beyond recognition i need a wiring diagram to identify the type
You have not mentioned what electronic equipment you are requesting the details.
You will be able to confirm the transistor value from the stage where it has burned which also goes for the resistor. So take tech help than to try with trials to damage the set much further.
Jan 31, 2011 | Car Audio & Video
I have 110 volt durapro 18volt dc battery charger, component R14 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
The component is a resistor. The problem is going to be determining the resistors value since it was burnt and you can not see the color code. You might try contacting the manufacturer and asking them the value of that specific resistor by including the number like you did in your post R14. If you can find a wiring diagram for the product, it should tell you the value of the resistor also.
I hope this helps you getting started in solving the issue.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Feb 07, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
No HT, components burnt
You can check out this website for your service information and parts: https://spares.bigwarehouse.com.au/index.php?cPath=24759_24762_24803 Paste the address in to your address bar. That will take you to the website. They had three of the four parts that you needed listed on the website 1.Q706 -Transistor bipolar FJAF5804 (TU) Fairchild $ 49.61 2. C744-Capacitor drawing SM SHR SYE/SWE 160V $ 19.06 3 R809- Resistor fixed small 1 ohm 2W 5% SF. $ 14.27 They also sold the service manual for $ 29.57. I hope this helps you with your problem.
May 12, 2009 | Computers & Internet
Resistors R30 and R31 on pcb 4233-1288d-b completely burnt.
R31 47 ohm 1/4 watt 5%
R30 100 ohm 1/4 watt 5%
Jan 26, 2009 | GPS
Burnt out resistor
I was not able to find a free service manual download. Here's is a site that has the service manual but is a pay site. click here.
Jul 03, 2008 | Samsung Televison & Video
Part identification
Thats a RCA You'll have a hard time finding the service manual to that. But when a resistor burns it usually means something else made it burn so you need to look into the cause or a new resistor will almost certainly fry as soon as you power up. Hope this helps.
Jan 14, 2008 | Televison & Video
HTS3300 Home theater system
It cant be know like that way! you need it to be repaired at service station only so they can trace it out!
Dec 08, 2007 | Audio Players & Recorders
Televison & Video Logo
106 people viewed this question
Top Televison & Video Experts
Ekse
