Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Vacuum Problem My dirt devil vacuum is losing suction and keeps clogging. All the dirt keeps sticking to the screen by the filter and then it would stop working. Also the hose does not have a strong suction power either. So what can I do?
  • Anonymous Apr 07, 2008
    the vacuum won't clean properly, the suction is very bad. Has this modle been recalled??
  • shugpug Nov 28, 2008
    this vacuum really sucks, I mean sucks as doesnt work very well, not sucks like it sucks good. after a few uses, even with cleaning the filter it barely works, picks up like 20% of what it should
  • 126 Answers
The Bissell can have several filters in it, depending on the model. Some have a round hepa filter that is covered with a foam sleeve. This filter is located at the bottom of the dirt cup. Others have a foam filter that is located under the dirt cup in a pull out drawer. Also, they can have a cylindrical separator above the dirt cup which can be removed and washed. They are usually a blue plastic and you reach in and turn it a 1/4 turn counter-clockwise to remove. If your machine has the hepa filter, when you remove the dirt cup, the filter is at the bottom and you turn the bottom 1/4 turn and the clear housing will come off to access the filter. You should also check the small filter on the machine just below where the cup sits. This will only be there if your machine has the hepa filter on it.
Posted on Mar 21, 2008
SOURCE:
How to fix dirt devil featherlite carpet cleaner loss of suction?
Hello! Below are general trouble shooting steps for your Dirt Devil vacuum to restore suction.
1. Check the hoses for clogs.
2. Clean and replace your filters if needed.
3. Check that your brushes are still spinning, if not, replace your belt with the recommended belt for your vacuum.
Hope this helps!
Jul 10, 2014 | Dirt Devil Vacuums
Dirt Devil easy lite makes pop or a thunk and then the suction is bad the clog lite does not come on I know it works
Hi, it's Cindy from Crucial Vacuum.
From your description, it sounds like there may be something stuck in your roller or your filter may need cleaning or replacement. Refer to page 22 of your manual to remove your roller.
For optimal performance, your filter should be replaced every 3-6 months and washed every 1 month. Your filter is located under the dirt cup holder.
You can purchase direct your replacement filter from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil-f43-easy-lite-cyclonic-hepa-filter.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 28, 2014 | Dirt Devil Easy Lite Quick Vacuum
Dirt Devil Ultra Vision vacuum- no suction?
Check for a clog at the neck of the "bag".
Sep 11, 2017 | Dirt Devil Vacuums
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
Feb 25, 2009 | Dirt Devil Featherlight Bagless Upright...
Filter clogs with every use
What should I do when the dirt Devil Vacuum clener doesn't **** up dirt ?
Sep 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
258 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
