Question about Vizio P50HDTV10A 50 in. Plasma HDTV
No screen display - VIzio 50" Flat screen TV
We purchased this TV about 6 months ago and image just went out. Green powerlight on, screen flickers for a moment as power light comes on but then it goes away. No power outages, not sure what's wrong, there's no image only power light remains on. Is this expensive to fix, please help! Please advised if there's an easy fix for this. Thanks.
  • 1 more comment
  • Anonymous Oct 01, 2008
    I have a vp422 model and the screen is completely out, however I have power, as far as the green back light, and orange front light.
  • delinger Nov 08, 2008
    Vizio 50 in plasma power comes on but no display, light turns green on front when pushed. does make normal click sound when powering on but nothing on the screen not even the No Input showing
  • Anonymous Mar 12, 2014
    I have a Vizio 80" tv. When I power it on, light on bottom comes on as if to turn on and then goes out and the screen is dark blue.
  • 2,326 Answers
If you purchased the TV 6 months ago, still under manufacturers warranty. They normally give customers 1 year warranty coverage.
It looks like the main board will have to be replace on this TV or fix to the component level.
Posted on Mar 21, 2008
Vizio tv screen went gray
Hi Mike,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 05, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
Vizio screen went white
Im sorry but did you figure this out yet. my tv just did this today too. it broke now.
Jan 28, 2010 | Televison & Video
My vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
Jan 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
We also have a Vizio with red horizontal lines and our TV is new
It's possible that the motherboard or the controller board for the screen is defective. At this point, I would use the warranty from Vizio. It should be no doubt that it covered. Here's the info you will need from the Vizio web site.
http://www.vizio.com/support.aspx?id=1588
Jun 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Our Vizio 32" that we purchased 13 months ago suddenly started putting a green tint on both our Direct TV and our DVDs.
This can be a failure in the display driver circuits, or in the display panel itself. This should be verified by the factory service rep. He will try the necessary modules to determine where the failure has occured.
If the set is out of warranty, this can be a very expensive repair.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
VIZIO BLACK SCREEN
That problem is the Ysus board, Sometimes people will replace the Zboard at the same time. If you bought it at costco a couple of years ago you are in luck costco will refund your purchase price, costco has changed the return policy and newer tv's are not refunded, but something to look into
Jun 06, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
No picture, sound works. Screen flickering
It sounds like the video output isn't
working its most likely a component
failure 1 thing you could try is connecting
a rca cables from video/audio out on the set to
another set vid/audio inputs to see if it the video gets
through.This is a problem that requires technical
knowledge and test equipment to trace the video
signeal
Nov 22, 2007 | Toshiba 50HP66 50 in. Plasma Television
That problem is caused by the Y Sustainer board.
Oct 12, 2007 | Toshiba 50HP66 50 in. Plasma Television
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
991 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
