I had the same problem and this worked.
Worked perfectly first time!! Thanks.
very helpful I couldn't believe it thanks so much back in business!!
Works perfect on my CX6400. Epson service aready informed me, that this printer is no onger supported and I have to buy a new one! Many thanks for your advice!
Excellent!!! I probably needed to clean the ink heads via this procedure: http://www.ccs-digital.com/Epson-head-cl...
but after doing that and seeing the red (!) warning, I knew it was just a matter of resetting the printer. Thanks a bunch for the key to doing that!!!
Worked perfectly the 1st time :o)
Excellent advice worked straight away!!!
You saved my ****. THANKS!
You saved my rump. Thanks!
Worked perfectly the first time on a nonworking printer that was given to me. If I had bought an Epson printer I would be finding out if there is a class action law suit against them for nonsense like this. At least my crayons don't quit working until they are used up!
Will not print on paper
SOURCE: Model Epson Stylus CX6400 Had several years but
Link to documentation and manuals:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=25723&infoType=Overview
SOURCE: Printer reads-"Printer error-see your documentation"... no clue as to what to do.
pull the plug and unplug it again..or load and unload your cartridge..,or change the cartridge you using...maybe the printer don't recognize the printhead..
SOURCE: When I turn on my Epson stylus CX6400, it has the
Do you have any other indicators such as flashing lights or similar?
My guess is that it MIGHT be a "service required" error meaning the waste pads are full in which case this guide may help..
There's a reset sequence you can follow near the end of the article which I'd try... If that solves it then you'll need to deal with the waste pads.. If not, you'll know it's something else and can report back..
SOURCE: EPSON STYLUS CX6400 Error Message Reads...... "Printer
you can find the manual here
http://files.support.epson.com/pdf/cx64__/cx64__qr.pdf
